Can someone make sure this is right
Ok so i ordered a Mechman 170amp alt and 1 XS power 5100 to replace the stock components.here is a drawing of what i intend on running.
All wire is Bullzaudio 1/0
The fuse between my alt and batt is 250A
front and rear fuse are 250A
fuse for sub amp is 200A
fuse for 4chan is 25A
Equipment-
1-1.2000D MB Quart Onx series@1ohm
1-Alpine Mrp-f240@4ohm
I do intend on getting a 2nd XS for the rear but its gonna happen for a month or 2,and with having a stock Bosch batt up front ive read that mixing them would have bad results for 1 or both of the battery's which is why i chose to replace the front 1st.Thanks for the help in advance!
2000 blazer LS
240 mechman
2 b2 HN v3 15s
crescendo bc5500 @.5
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/
142.8db MECA
2016 PA state champ mod 1 class
IMO you have the right idea but 4 fuses in the run going to the back. I would check to make sure that you don't have any voltage drop at the amplifiers and add another battery asap
thank you sir.i will be contacting you for another d5100.
2000 blazer LS
240 mechman
2 b2 HN v3 15s
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
142.8db MECA
please tell me you are removing all stock wiring
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
as in redoing the factory wires from batt to starter/alt/fuse box? Or adding the 1/0 + and - from mechman alt to my d51?<doing this ..didnt think i needed to replace the others
2000 blazer LS
240 mechman
2 b2 HN v3 15s
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
142.8db MECA
fusing alt to battery is pointless if not removing factory wiring. i don't understand why people do this. agreed with earlier post, you have too many fuses.
Ok i see what you mean..nothing is done to the car yet,thank you for the input.Waiting on PA weather to cooperate
2000 blazer LS
240 mechman
2 b2 HN v3 15s
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
142.8db MECA
actually, it is easier to leave stock wiring, and add on top of it. Leaving stock wiring doesnt hurt anything.
edit: electricity will take the path of least resistance, so having the stock wiring along side upgraded added on 1/0 wiring wont hurt anything, and in reality, it helps ever so slightly (to the point of being negligible).
Thanks guys will post pics friday evening i hope
2000 blazer LS
240 mechman
2 b2 HN v3 15s
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
142.8db MECA
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
