Using 4ga for an amp with 1/0 inputs?
i planned to do that with all my 2 chan amps no 4g at all all 2/0 and 1/0. the only thing with keeping the gain way down is you will always want more so if u dont have the proper self control to leave well enough alone i wouldnt even do it.
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Yea, he wants to keep in the 2200, until he gets the 1/0 but I'm gonna tell him its a bad idea.
2001 Chevy Blazer LS
Kenwood KDC-HD552U
2 12" SDC 2.5 D4 Fi SP4 18" 4 Sundown SA-12's
HiFonics BE 1200.1 Soundstream RUB1.2500D Looking for a 5k
XS Power D3100
4 Soundqubed 6.5's (Pro Audio)
2 Soundqubed 3-Way 6.5's
2 Soundqubed Super Tweeters
I run 4 ga stinger ofc to my BRZ2400(that has 0ga terminals) haven't had a problem yet. And don't have much drop..
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
In short, Here is your answer.
Too late he's already running it.
2007 Pacifica
TOOLMAKER! Bass ass huh. Great price and have some of there batt terminals too. Great line of products, wish i had know about them sooner.
Can you yes, should you no.
The issue IMO isn't the amp it's the fact that 4 gauge wire is roughly 150 amp current draw capable. Now on music daily I couldn't see the amp pulling more them the wire can handle. If it's fused directly (fir the amperage current rating of the wire as stated by manufacturer) then the worst thing that would happen is a blown fuse. If there is no fuse you could easily end up with a fire.
Now as for the amp, if your not drooping to low of voltage and it's not getting to hot to touch I would say it's safe but not wise because the above reason.
Simply put the write will bit like 200+ amps of draw and could go up in flames with improper fusing.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
