heard about some WASRs doing that.
too loose or tight?
if its a saiga conversion itll only take saiga mags
just some second hand stuff ive heard on forums and what not. i dont know how truthfull they are
98 Mustang GT
Singer 320
2 12" Incriminator Death Penalties
1 SAZ-2500dv2
2 D3100,1 D3400
2 Crescendo CZ-65
SAX-100.2
Door panels by Diablo Kustomz
if they fit too tight sand the mag a bit or it will also wear out on its own to fit.. if its too loose you have to weld some metal inside.. on mine the plastic mags fit tight and the metal one is a bit loose but not as bad as the first run of the wasr 10. mine already has been welded inside
edit: looking at the gun it looks like it already has a dimple to help with the loose mags.. if its a tight fit use it a bit to loosen up
Its an Inter Ordnance (I.O.) "Hellpup"
The mags fit snug on the sides, its the back corners of the mag (above the rear lug) that won't allow it to rock in and seat.
There's a gun show this weekend and I'm gonna see if i can pick up a couple steel mags or AK PMags before decide on sending it back or busting out the file and slowly make it work.
  • Who's Online   0 Members, 0 Anonymous, 1209 Guests (See full list)
