1 sub doesn't play lows. **video pg 2** issue solved.
Did you check the wiring on the other sub? Could be a plus or minus swap on that sub as well. That will cause what you are describing.
Did you get a chance to switch the sub location?
Does one sub get warmer than the other?
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Wasn't playing long enough to see if one gets warm.
Havent checked wiring or switched sub locations yet. Just doing house chores and uploading my video.
Video
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Issue solved. One sub has a bad side of the coil.
The sub that was moving normally checks out at 2ohm per coil and 1 ohm at the amp.
The sub that wasn't working correctly has a side reading 2ohms... and the other side reading no ohms.
At least i know that I'm not retarded at wiring!
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Ill post pics if you guys want. the sub is pulled out.
One of the jackets on the direct lead broke and looks like it might have shorted on the basket. Dafuq?
Can that happen?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Kyle beat me to it lol
But shit.. Sorry to hear Jeff.. At least you got it figured out :shrug:
I try not to fuck with AC electrical, so I don't have an answer for you.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Eh... Its all good. Anyone know someone good with woofers to tell me exactly what happened? Ive went past the direct leads and touched the actual tinsels.. Still no signal on that one side.
So is it possible to blow just a single coil and the other side read fine?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Damn man. I had the same issue with some XL 18s. One sub popped and one coil stopped reading. Coil was perfect, tensiles looked good, couldn't figure pit the problem so I just reconed it.
(1) Mechman 240
TEAM NWSPL
155db outlaw
Odds are its not fixable without destroying it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
well thanks for chiming in guys. I appreciate the help. Hopefully i can get this fixed. It kinda sucks too.. my system was finally where i wanted it to be for a little while.
I guess when they say it never ends.... IT NEVER ENDS.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   0 Members, 0 Anonymous, 2853 Guests (See full list)
