1 sub doesn't play lows. **video pg 2** issue solved.
Soooo.....
Amp reads .5ohms like it should.
All coils read 2ohms like they should.
No box air leak.
I'm like 99% sure I'm wired in phase. (I recently re wired both subs because of adding carpet so I wire might have gotten switched, but I checked and it and it looked correct.
Both subs play above tuning loud and what looks to be in phase. Both move the at the same time and distance. But below tuning (31hz) the passenger sub doesn't move. The kick (punch notes) will play but a continuous bass note won't.
(Here's where it gets weird)
Take both subs out. Both subs move awesome.
Take one sub out. Both move awesome.
Sounds like a out of phase issue right?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
All I know is that there was an exact thread about this shortly ago. Many people asked if the subs were both new or both had same amount of play time. He never answered and got all pissy about it later on.
But I know yours have the exact amount of play time.
that's all I can add.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Yes they are same age. Technically one recone is a day newer then the other. Both have never seen any other amp or power. Neither has been played more then another. And they have only been played next to each other (free air or in box) never individually wired to my amp.
Edit.. Same motors. The only way to tell the difference is one motor has a nice scratch on the bottom one doesn't.... Other then that they are identical.
I'm tempted to check the wiring on the other sub tomorrow. (The one that doesn't move was checked and re wired today)
I'm also tempted to switch sub locations and see if it follows sub or follows side.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Pics of box design, and specs.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
So, below tuning.. One sub just doesnt move?
Maybe it is just an illusion.. Maybe one is moving in and the other is moving out? To me, that'd sound like a phase issue.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
BHE box. No design and specs available. Box played fine for months.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
It's an illusion that a camera, my girlfriend, and I both seen.
Not sure if it is a phase issue for sure. Sounds like it is though.....
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Can you upload pics of the box and/or design? Who designed/built it? If it's only below tuning, could be an enclosure issue. Normally an out of phase issue would be across the entire bandwidth. Is this on both full and low power?
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Switch the subs. As in if sub 1 is in cutout 1 and sub 2 is in cutout 2, put sub 1 in cutout 2 and 2 in 1.
Then look to see if the same sub or the same cutout is having the issue.
Im really liking this idea.
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 6811 Guests (See full list)
