I've been looking into an H.O alternator for awhile now. I know I could jump on a Mechman or DC, and be content. A company popped up that I never heard of before, and considered giving them a shot because they seemed new, and the price for output looked nice as well.
Something that caught me off guard was it being internally regulated. All I can remember reading about was either PCM through the car or having an external regulator for the alternator.
What pros and cons are there to being regulated internally?
Also it only has a 1 wire hook up, being the positive stud, and nothing for the factory 2 pin (dodge). Is that going to be an issue with the vehicles computer?
Not going to expose any names yet, but I really don't want to be buying into an "ebay" alternator.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Eh, a shit load of alts are internally regulated.. like mine (factory and HO). Im sure your factory one is too.
As far as the computer, idk.. I know that it'd cause an issue with mine, based on how my "electrical light" circuitry is.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Ah, so the two pin connector doesn't go to regulate the alt somewhere else? I'm not completely alternator literate here.
I figured either way, something in the car would not be happy if the 2 pin connector wasn't hooked up.
For my car, i have 2 pins.
One pin gets power when the car is on to turn on the alt
The other pin is wired to the battery. When battery voltage is low, the alternator "puts more work in." When the battery voltage is higher, the alt takes it easy.
Off topic.. is the alt a JS UltimateSounds alt? Just curious.
LMFAO so true
:blush:
if its like mine truck which is pcm control you can bypass it my alt has 2 studs and the batt stud when I get ho alt I'm getting this C8313 its adjustable voltage. just like hdorre said the other pins is for when the the car needs more power and also when you turn on the ac it'll kick the voltage up.also if you don't want the check engine light on you can get this kit form http://alternatorparts.com #ERCKFRM it has everything you need
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Ah ok that makes sense. If I crank my system out of no where, it drops MUCH lower than if I had been playing for a bit. I'll have to ask again to make sure that there is/isn't a 2 pin plug on it.
Nope, company coming out of florida. Just hoping that this isn't tenny renamed.
Do you have money to blow? If the answer is no let someone else guinea pig. Remember Tenney had good reviews at first too
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Point understood.
I just like to try and give small businesses a chance if I can. i.e. the tint on my car.
edit: another thing that was sketchy. He wouldn't give me a straight answer on what idle output would be. Kept saying that the alts were only tested at 1500rpm hot. Which at least they test them hot.
Ehh.. the idle worries me. Id rather have an alt that does 180/200 than an alt that does 100/220.. With no verification.. uhm.. no thanks
Peak isn't everything.. Especially in most autos.
LMFAO so true
:blush:
the plug realy don't matter you just get a check engine light I know someone that upgrade their alt they just went interal with just plug which one wire is hot the other is a switch and also the batt stud
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
