FI Q 15 and hifonics colossus system - HELP!
Hello, I finally got the chance to build my system. In all it's a hifonics colossus 6.5k dual mono amp with 2 FI Q 15 subwoofers that are 2 ohm dual voice coil. After everything was set up and ready to go I had the subs wired down to 1 ohm each and put into each of the two channels. At a low power everything works fine but as soon as I start to really put some real power to them the amp cuts and goes into protection mode. On the amp, the diagnostics led indicates a short. As far as power I'm running 0 awg from a battery in the back of my car. That is finding a ground off a fuse block under my back seat. As far as the subs, they are 12 awg. As I believe to be the best of the best car audio guys, does anyone know what I can do or recommend any ideas? Thanks!
Whats your electrical like(batteries, alternators). Edit. Like eminece said find a better ground, seat bolds are a last resort for ground. Best place is the frame.
I would try a different ground. Bodys arent the best ground point. If you can, perhaps run another 1/0 gauge wire to ground. If thats not a option, take a cordless drill or grinder and make a part of your frame clean and bolt the ground to there. I assume you have the big 3 already done.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
I'm thinking (without actually looking it up) that your amp is a single channel amps but has two terminals for hookup for ease of wiring so wiring each sub for one ohm then plugging both into the amp your amp saw 0.5 ohms and is protecting because of the low ohm load since it's rated at 1 ohm
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
So then you have a .5ohm load. Is your amp .5ohm stable? Have you checked with a meter to see if it's actualy .5ohm or lower. I know when my boy ran the Q's the load was lower than .5.
truthsayer
Q's come in d1.4 coils.
2 subs with dual 1.4 coils if you parallel parallel wire them you will see a nominal of .33333ohms <- really freakin low.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Option 1. Recone subs to proper ohm load needed for that amp.
Option 2. Sell that amp and get a huge 5k or 7k amp and run it at 2ohms (1.4 because FI) nominal (amp won't work hard and you will still get 3k ish rms)
Option 3. Sell that amp and get 2 1500-2000 watt amps and run each sub on a single amp at 1ohm (.7 because FI) but then you have the issue of gain matching where you will need to find a dd1 and cc1 to set it up.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   2 Members, 0 Anonymous, 1133 Guests (See full list)
