NEED HELP W/ FIRST MAJOR WIRING INSTALL!!!!
Here would be how You would fuse, green lines are fuses. Wiring is your preference though as far as how many runs, i would do 2 personally. And like everyone said, you will want probably 2 G31's in the rear.
DAAAAAAAAAMNNNN!!!!!!! YOU JUST MADE IT ALL SO SIMPLE MAN!!! I appreciate it. Would i just run pos to neg together with an additional battery in the back?
But What Do I Know?
2003 Chevy Monte Carlo SS 3.8
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Ascendant Audio 12" Havoc v.1
  • Ampere Audio 2000.1
  • MB Quart Onyx 800.4
  • XS Power D3400 - Hood
  • XS Power D975 - Trunk
  • Singer 240A
  • Sky High OFC 0 & 4 gauge
  • Kno Knoise Kolossus Deadener
yes. all that would change is a positive and negative jumper on the back batteries to connect them in parallel.
Thats alot of power your amp puts out for 1 battery in the trunk, maybe another would help. Plus you still have mids & highs to run off that electrical too. I would run 0 AWG and at least 1 run if not 2. Depends on your budget i guess. Electrical is the most important part of your system IMO. Save up and do it once and do it right.
0 AWG allows more amperage to run thru the wire
Fuses @ each end of runs and after batterys to distrabution blocks
Do lots of research, look at pics, decide on wiring routes, amp placements. And take your time. Good luck.
thanks man, yea i plan on adding another xp3k to the trunk. I want my voltage to sit at the minimum, 13.5. so taking my time with the electrical is not going to be an issue.
i disagree with this drawing. You need to get alt runs to the rear bank
He does.. using the front batt terminal
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
You do not need alt runs directly to the rear bank
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
no you dont..... they do by default off the front battery....
I have zero runs from my alternators directly to my bank. I'll stand by mine. Maybe if you struggle with keeping your rear battery voltage up it would be optimal but at that point it becomes an alternator issue and not supplying enough power I have 6 and 6 runs to the rear. I can guarantee that I would gain nothing doing a run to the rear from each alt.
what's your belief that it's optimal
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
For what ever reason, I have both.
2 runs off the alt stud. One goes to the front 3400. From there 2 runs to the back bank.
Second off the alt stud goes back to the back bank.
Just because. :shrugs:
For what the op is doing, like I said, Chevy boys illustration is fine.
  • Who's Online   0 Members, 0 Anonymous, 1056 Guests (See full list)
