Daniel Joseph Bragenzer Bond Posted May 8, 2014 Author Report Posted May 8, 2014 no. they were tested togethere in the car
Daniel Joseph Bragenzer Bond Posted May 8, 2014 Author Report Posted May 8, 2014 should i still take them out and have them tested indivisually?
Noel989 Posted May 8, 2014 Report Posted May 8, 2014 should i still take them out and have them tested indivisually? Yes Build Log - http://www.stevemead...-cruiser-el-pt/
Bump4life Posted May 8, 2014 Report Posted May 8, 2014 yes test them each individually. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Daniel Joseph Bragenzer Bond Posted June 12, 2014 Author Report Posted June 12, 2014 well . the 2 HC800's under the hood I'm pretty sure have been overcharged. After taking them out. I noticed the positive terminals were both raised and the seal around it is cracked and seperated from the post. SO .. They toasted i say. Any how.. I got Put a new XS power D6500 under the hood now. Voltage all the way around looks better now. Seems to rest about 13.1v now till it sits for a while . then to 12.8v. But the problem still exsits. I can get it up a little louder now. but the bass amp still kicks off. So I guess its off to the rear batts now. Got the subs out. examined the 2 HC2400's . only thing i see on them is the negitive post seem raised. but all the seals look good. My guess. They are bad to. So time to save some money again. 2 XS Power D3100's are going in. Bye bye Kinetik
Daniel Joseph Bragenzer Bond Posted June 12, 2014 Author Report Posted June 12, 2014 also the burnt cable came out and now there is 2 runs of 1/0 from front to back batts.
Daniel Joseph Bragenzer Bond Posted June 17, 2014 Author Report Posted June 17, 2014 Got a hold of kinetik. they are replacing all my batts for the shipping charge . Thank God. Thank U Kinetik.
Daniel Joseph Bragenzer Bond Posted June 17, 2014 Author Report Posted June 17, 2014 All my batteries went bad . And yet that still wasnt what was causing this problem. I think I have it down to a Bad ground. Maybe something happend to the ground when i had my little fire under the hood touching the uni-body.Old ground was to the uni-body. It was good before the fire. but now is no good. Going to change it to ground to my alt case. I hope this is it. Tired of this headache. Anybody else have a groung go bad on them? First time for me
Daniel Joseph Bragenzer Bond Posted July 1, 2014 Author Report Posted July 1, 2014 well everything has been changed now.. Batts are new. cable is new ..new alt . back batts are now grounded to the alt case. voltage with car on is now 14.7v and with the car off and rested for a day its sitting at 13.1v. And Still my bass amp shuts off when turned up more than half way so fustrating. Anyone know of a good shop to have this amp checked out? Or does anyone know of a good 5,000watt rms amp at 2 ohm.. been looking around and have only found 1ohm amps. Im running a 2 ohm load and need at least 4,000 rms to push these RE XXX's. Any suggestions? best i have found is 2- sundown audio saz-2500"s strapped togethere. But they are'nt available on line. will have to go to a dealer for those. Any ideas?
gr8handogoatness Posted July 1, 2014 Report Posted July 1, 2014 Did you also check the amp grounds? Still sounds like a ground problem to me.
