2 4" aeros with one 15, help with box!!
I guess that the flared length that PSP gives is for their particular flares, generally speaking the effective length of a flared port is calculated like this:
The effective length as shown in the figure should be the 8.9".
If thats the proper way to make the port length then that lowers my tuning some i think. Doesnt matter, building a new box with 10s anyway.
this helped allot for me to! i plan on making my own flared and was wondering if you could flare them to much
from what I've searched i don't think you can flare them too much as long as the effective port stays the right length. i believe that no matter how much you flare the port only 1/2 an inch or so of the flares will actually be part of the port because of size.
that's good news! I'm flaring both ends so it will be easy to make.them exact
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
i always flare the 4" pvc tubes with a heatgun and a bowl, and, i always cut them about 2.5" longer that what i want to use because each flare takes about 1.25" , so in other words, if i want a 17" long port with flare on both ends, i cut them about 19" long and flare them
  • 4 weeks later...
instead of 2 4" ports could i use 4 2"? it'd still be the same port area wouldn't it be? i may even just use 6 2" the 4" pvc i had laying around was the heavy duty sch80 stuff so its much more thick than normal (sch40) pvc.
4 2" port is the same port area as 1 4" (12.56 square inches). You can get standard 4"PVC in smaller lengths for really cheap.
Why not a single 6-8" PVC port. You can get either one through home depot or lowes.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Round port area
rxrxpie.
2" port
1x1x3.14=3.14 4=12.56 6=18.84
4" port
2x2x3.14=12.56 2=25.12
6" port
3x3x3.14=28.26
as you can see you would need around 8-9 2" ports, 2-3 4" ports or just a single 6" port.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
He states that he wants the sub at the center of the baffle, ports on the sides.
oh crap okay. i'll probably do 8 2" ports then. i don't have a lot of spare money after bills, (I'm 17 and have lived on my own for over a year now.) so i was wanting to just have to buy the mdf and use the pvc i have already.
  • Who's Online   0 Members, 0 Anonymous, 564 Guests (See full list)
