hankfan79 Posted March 30, 2014 Report Posted March 30, 2014 What would be the difference in wiring two batteries in parallel vs wiring both batteries to the power pole of a alternator? Provided both batteries are the same with same wiring. Alt + to Front Batt + Front Batt + to Rear Batt + or Alt + to Front Batt + Alt + to Rear Batt + What's the difference if any?
n8ball2013 Posted March 30, 2014 Report Posted March 30, 2014 None really. Some like to run from the alt to the rear batteries. Im not one. You may also have a tough time getting two runs on the positice stuff of an alternator THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
SnowDrifter Posted March 30, 2014 Report Posted March 30, 2014 Mine goes from alt straight to the rear. No problem getting.. Lets count... 1..2.... 6 wires on mine Stock wire, positive to battery, wire to regulator, 3 runs to the rear. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
hankfan79 Posted March 30, 2014 Author Report Posted March 30, 2014 Positive pole is big enough (Mechman). So drift you go straight from alt to rear battery? Any reason why?
SnowDrifter Posted March 30, 2014 Report Posted March 30, 2014 Alt is where the power is coming from. So I go straight from there And on my car, easiest place I found to run wire was on the passenger side. Battery is on the drivers side. I'd go from alt, to driver's side for the battery, back over to the passenger side. It would have been a waste of wire. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
hankfan79 Posted March 31, 2014 Author Report Posted March 31, 2014 Alt is where the power is coming from. So I go straight from there And on my car, easiest place I found to run wire was on the passenger side. Battery is on the drivers side. I'd go from alt, to driver's side for the battery, back over to the passenger side. It would have been a waste of wire. My setup is same. Alternator closer to passenger side. Battery across the way. Ok, so next question: This wouldn't be ideal if the rear battery was a smaller reserve battery would it? D925 in the rear.
alaskanzx5 Posted March 31, 2014 Report Posted March 31, 2014 I know mechman doesn't recommend running multiple wires from the alt. Talk with them about it. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Jhunt94 Posted April 1, 2014 Report Posted April 1, 2014 I know mechman doesn't recommend running multiple wires from the alt. Talk with them about it. ^^ I've also read that in some other threads on here. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
