Hifonics amps.
Quan804
Sonic has good pricing on RE audio amps from time to time
so whats your affiliation with re? Every post you make is about them.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i have 2 of the BRZ 2400.1 strapped and i think they are pretty decent little amps
They're power hunger amps.
The BRZ 1700.1 did rated power on a dynamic power run which is what we all do with daily setups driving around town.
OP, spend your money where ya want, on what ya want. I would listen to colin since he has been running his since 2008. I have had mine for alitte over 2 years.
just set the gain proper, tune the headunit right, proper voltage and grounds and you should be good if you choice the hifonics
You are kidding right? dynamic power is NOT what we all do in daily setups. So you are telling me that you play songs that have 1/10 of a second bass line??? haha
The only real number to look at is certified. Do you remember what it did offhand? Or do you only care about the MAX or DYNAMIC aka bullshit ratings?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
http://www.stevemeadedesigns.com/board/topic/175248-amp-test-tuesday-hifonics-brutus-elite-be17001d-rated-1700x1-win-it-pre-guesses-inside/
brz1700 "elite"
SMD amp dyno
certified 1199 @1ohm
uncertified 1401 @1ohm
dynamic 1812 @1ohm
yea have fun with that.
lol as if ya'll are gonna hear the difference between 1400 or 1700 rms.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
hifonics does not do rated,dont care what anyone says.. RE are junk too. i have ran both of them and they are not good for what you pay for.. get a saz1200 and it will run circles on the brz1700.. you want good for what you pay for get the crescendo symphony 1500.1. its rated at 14.4 yet does 1762 at 13 volts certified.. for $300 it tops the hifonics hands down
http://www.droppinhzcaraudio.com/s15001-p-316.html
Parts from the manual
Using Certified Dyno Mode
A Certified Dyno run will increase the amplifier's output
power until more than 1% harmonic distortion appears
on the output. The AD-1 will only read power that was
made while the distortion was less than 1%. If you have
a noisy or dirty amplifier or noisy system this test may
not work well for you. You will know if you have this
problem because the wattage displayed will not increase
steadily, it may increase in big increments or not
increase at all. Additionally the distortion LED will be
illuminating. In this case you should find and correct the
distortion problem with the audio system, or use the
Uncertified Dyno Mode. The B+ voltage that is
displayed on the screen corresponds to the B+ voltage
at the amplifier at the exact moment that the last highest
clean power reading was taken.
Using Dynamic Power Mode
A Dynamic Power Run will send a burst sine wave signal
through the amplifier to measure the amplifier's ability to
produce the dynamic peaks contained in music. The
AD-1 will read the highest clean power that was
produced during a burst. The B+ voltage that is
elect START DYNO and unpause the track. (The
track contains 5 seconds of silence followed by 10
seconds of burst tones, followed by 5 minutes of silence
so the operator has time to record the measurement and
stop the track).
11. The AD-1 will display the true maximum RMS
dynamic power per channel that was produced before
clipping of the signal occurs, and the corresponding B+
voltage for the measurement
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
stop the track).
hey Mr DERP DERP. So you are telling me you listen to music that has 1/10th of a second bass lines. Anyone can read instructions. It takes mild intelligence to interpret.
  • Who's Online   1 Member, 0 Anonymous, 1469 Guests (See full list)
