soundstream15 Posted April 3, 2014 Report Posted April 3, 2014 I have a 3.5krms amp, I have 1 main run of power wire it's old tsunami wire. Was gonna upgrade that to some sky high, should help voltage a tad but would it be better to do 2 runs of CCA instead of 1 run OFC? I'm sure some ppl would run 2
ToNasty Posted April 3, 2014 Report Posted April 3, 2014 what alt do you have? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
DubNDodge Posted April 3, 2014 Report Posted April 3, 2014 I would just do 1 run of ofc. Granted you will have the more potential to carry more current with two runs of CCa, but you will be using more fuses, holders, and lugs/ring terminals doing those two runs. Plus it can be a PITA to do multiple runs. Unless you are going under your car. Plus if you ever decide that you do want to run ofc, you wouldn't have to swap out the CCA. just add onto what you already have. That was my main reasoning behind doing OFC '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Trey_Dog650 Posted April 3, 2014 Report Posted April 3, 2014 For a 170 amp alt I'd do 1 run of cca 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
ToNasty Posted April 3, 2014 Report Posted April 3, 2014 For a 170 amp alt I'd do 1 run of cca exactly, your only producing 170 amps so wire and fuse for that 170 amps ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Kyblack76 Posted April 3, 2014 Report Posted April 3, 2014 For a 170 amp alt I'd do 1 run of cca For a 170 amp alt I'd do 1 run of cca exactly, your only producing 170 amps so wire and fuse for that 170 amps OH MY GOD !!! SOME ONE GETS IT FINALLY !!!!! fuck SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
DubNDodge Posted April 4, 2014 Report Posted April 4, 2014 For a 170 amp alt I'd do 1 run of cca For a 170 amp alt I'd do 1 run of cca exactly, your only producing 170 amps so wire and fuse for that 170 amps OH MY GOD !!! SOME ONE GETS IT FINALLY !!!!! fuck I just like over kill '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Kyblack76 Posted April 4, 2014 Report Posted April 4, 2014 For a 170 amp alt I'd do 1 run of cca For a 170 amp alt I'd do 1 run of cca exactly, your only producing 170 amps so wire and fuse for that 170 amps OH MY GOD !!! SOME ONE GETS IT FINALLY !!!!! fuck I just like over kill 5 runs, when you dont have the output to cover one run...... isnt over kill thats retard. A knowledgeable builder would look at that, and giggle inside. Using your resources wisely, is as respectable as anything. EDIT - Im NOT saying be cheap. Im saying use your brain, and get/do what you need for what your doing....... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
