heightzbest562 Posted April 4, 2014 Report Posted April 4, 2014 i have a 18" teamfi car is scion xb i will try to keep back seats and use C pillar for bas box ect... the space i have to play wil overall is L 37" x W14" x H26" is that too small ? its about 7.7 cubes overall
JakeBoucher Posted April 4, 2014 Report Posted April 4, 2014 For a single 18 that sounds like plenty, Being my 2 15s are in box around 8 cubes "Dude the more your sub weighs the more watts it puts out"
Joe X Posted April 4, 2014 Report Posted April 4, 2014 i have a 18" teamfi car is scion xb i will try to keep back seats and use C pillar for bas box ect... the space i have to play wil overall is L 37" x W14" x H26" is that too small ? its about 7.7 cubes overall That's the external volume, not net, net is like 4.5 cubes after wood, proper port, driver displacements and that's low for that sub.
Miguels Posted April 4, 2014 Report Posted April 4, 2014 its a no go.. best you can do a a 15 maybe 2.. taking into consideration batteries and amps in the rear my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Katt Posted April 4, 2014 Report Posted April 4, 2014 If you do external aero ports you could manage it. *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch*
kirill007 Posted April 4, 2014 Report Posted April 4, 2014 If the space is too tight, then your equipment ain't right. Thinking is the root of all problems... You ALWAYS get what you pay for.
john253a Posted April 4, 2014 Report Posted April 4, 2014 How much power are you putting to it If you close or on 4k You may just make it work
heightzbest562 Posted April 6, 2014 Author Report Posted April 6, 2014 How much power are you putting to it If you close or on 4k You may just make it work yes ill be putting in 4k
heightzbest562 Posted April 6, 2014 Author Report Posted April 6, 2014 update info........ i might be able to do L37" x D17" x H26" that would be 9.4 overall
