Wall help, please!
The wall does not flex...but the wall is flexing.
I'm a little confused...
The baffle is the whole side of the enclosure that the subs are mounted to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I think he means his box is almost jumping.
Did you bolt the box to the body and or frame?
Okay maybe this will be more clear.
I don't know if the image will show up but this is how my subs are mounted, looking in through the port. It's a 4th. Probably should have made that more clear.
This is exactly where it's flexing. On the left of that image is the panel in which I have the port, but it is not flexing. It is just this area. The foam overlaps the MDF a bit by about an inch. There are 2 more sheets behind this one. Before the "lol looks great" I haven't finished making it look all pretty, at least on the outside haha! It's been too cold in Michigan to do any work.
Nah man, it's cuz of the bass.
Where in Michigan are you?
if its the beauty panel, how is itattsched?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
A pic that shows more of.the whole box would be nice
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I'll take one later on tomorrow... Didn't think to and it's a bit too late now. I'm in Detroit metro, though I'm currently in Mt. Pleasant for the next 3 weeks or so. I didn't know it was called a beauty panel, I'm just using it to seal the cabin and it's anything but pretty at the moment. It's attached by 2 metal brackets on each side of the enclosure (total of 8 )in addition to a load of PL Premium and expanding foam. There are 3 layers, each is glued to the others with titebond III.
There are members in the Detroit area that could maybe take a look at it in person. Look up the Michigan people thread
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 1601 Guests (See full list)
