Ok so read here, i take this as car off.. Now class open you manual to page 4..lmao Im sure you can do it either way..But i choose to follow instructions as i see them..
http://damoreengineering.com/documents/Distortion%20Detector%20DD-1%20Ver.%205.pdf
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
And i would assume gain would be lower with car off, if its picking up distortion from charging system.. I would go test this but i cant get to my amps that easy..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Rootbeer, I agree with engine on. But SMD recommends setting with engine off to cover their ass.
Why wouldn't you set it how you run it?
Cover their ass from what? I was told to set with the engine off to reduce the chance of extra noise that could be in the system.
Seems like the question is what effect input voltage (power side not signal side) has on gain. I won't pretend to understand enough about how amps work to know the answer.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Just reading the link means to me that you shouldn't try powering the dd-1 from a cars charging systems it's not saying not to tune it when the vehicle off. It specifically says that it uses the 9v battery so it will measure distortion in the audio signal and not noise in the charging system.
Good Call :good: Long day at work...
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Tune with the car off... From the man himself.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   1 Member, 0 Anonymous, 1284 Guests (See full list)
