Hammer Knock Posted April 18, 2014 Author Report Share Posted April 18, 2014 yes amp plays. i plain to make more videos of what its doing and the steps you guys tell me to do. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
n8ball2013 Posted April 18, 2014 Report Share Posted April 18, 2014 You need help from the spuds huh? Irony THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Kyblack76 Posted April 18, 2014 Report Share Posted April 18, 2014 What all is plugged into the amp output? I see the red dd1 probe and something else? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Hammer Knock Posted April 18, 2014 Author Report Share Posted April 18, 2014 one speaker wire (neg) it did same thing with no speaker wires in. this did not happen when tuning the ap3k when neg of dd-1 to neg of amp. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
TCooper Posted April 18, 2014 Report Share Posted April 18, 2014 Connection depends on when the DD1 was made from what I found. If in doubt, contact the manufacturer with your serial number (under cover on the back of the unit) and explain the situation so they can confirm correct testing procedure. I just got a DD1 from Sonic. In the manual under setting the gain on a full range it states: "5. Using included harness, connect DD-1 to output of amplifier. Connect the red harness lead to the Left Speaker (+) terminal, connect the black to the Left Speaker (-). (Note: Most multi-channel amplifiers have the signal on the Left (+) and Right (-). " Said the same thing for the sub amp gain set. This puzzled me as all the videos I watched, including Steve's video, showed the black lead going to the amp ground. I did not want to screw up my new DD-1 so I contacted damore engineering. Here is the reply I got on the latest DD-1: Hello, We are in the process of changing the procedure, you can connect directly to the amplifier as your owner's manual states. The issue we were having was the dd-1 being damaged by big amplifiers. Since then we have revised the DD-1 Board and it is now capable of handing higher voltages. The reason we also changed the procedures was that some differential output amplifiers like the JL Class D amplifiers you would receive false readings. Hope that helps. As I said, double check with the manufacturer (and your manual if you have one to see if it reads the same as mine). Cheers Link to comment Share on other sites More sharing options...
CleanSierra Posted April 18, 2014 Report Share Posted April 18, 2014 The alligator clip IS an alligator clip for a reason. It's meant to grab some stands of the ground wire. Where is the BATTERY grounded to? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Amart88 Posted April 18, 2014 Report Share Posted April 18, 2014 The alligator clip IS an alligator clip for a reason. It's meant to grab some stands of the ground wire. Where is the BATTERY grounded to? This My 2005 s10 blazer build. 4 zcon 18's walled. Link to comment Share on other sites More sharing options...
Hammer Knock Posted April 18, 2014 Author Report Share Posted April 18, 2014 The alligator clip IS an alligator clip for a reason. It's meant to grab some stands of the ground wire. Where is the BATTERY grounded to? irrelevant? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Hammer Knock Posted April 18, 2014 Author Report Share Posted April 18, 2014 im basically using the ground of the battery for the dd-1 if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL Link to comment Share on other sites More sharing options...
Awhitewookie Posted April 18, 2014 Report Share Posted April 18, 2014 This is interesting. I followed instructions to the t and didn't have one issue tuning my bc5500 MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts. Link to comment Share on other sites More sharing options...
