What size plexiglass?
gckless
I want to put a 9"x18" (really 7"x16" because of the 1" wood overlap on each side) window in my next box. Sub will be a 24" SHD on 5k.
Can I use 3/4" or do I need 1"?
I would like to not use 1" if I don't need to, because that would mean I have to rabbet out 1/4" and I will only have 1/2" for screws to bite into. Plus, I don't have a rabbetting bit. But I know there's going to be a ton of pressure in there.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
If you can find a way to brace it,3/4 would be fine IMO
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
You mean like in the middle of the window? Definitely don't want to do that.
i think if you did a 2 inch over lap instead of one you'd be fine! is this a vented/ported box? also where in location to the sub is the window? I'm gonna guess right behind the magnet? i think you should be fine! 3/4 plexi is really strong!
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
I think 3/4 is totally substantial enough even without extra bracing. Those dimension are not wild enough to justify anything thicker.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
agreed, if it was a whole side or loading wall then yea but a window should be fine. that sub is pretty nutty tho
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Heres how I look at it. If you are on the fence go up. No ones ever suffered from over doing it. One can suffer from not doing enough. Youll have enougg power.for things to go wrong alot faster than you may be able to catch
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
True, or just make the window a lil smaller
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Thanks for the replies.
Yeah I hear ya. It's not that I'm on the fence, it's that I have no idea. Never used plexi thicker than an amp cover. But I am going to use 3/4", unless someone chimes in that has used either sizes on around this power and says that 3/4" definitely won't work. I figure this is a fairly small window, and plexi is stronger than the wood I'm using, so I should be ok. Should.
  • Who's Online   0 Members, 0 Anonymous, 3203 Guests (See full list)
