Tecomah Posted April 21, 2014 Report Share Posted April 21, 2014 There quality has seemed to drop in the past couple years. I have a family friend who is an old old school basshead and he used to love their stuff, but won't touch it now 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows Link to comment Share on other sites More sharing options...
Aj11 Posted April 21, 2014 Report Share Posted April 21, 2014 it says list price $439 what is the sale price? I've never heard or seen those amps but no way in h e double hockey sticks would i spend $400 on that amp. so what is the actual price on it? if it's.in the $250-275 area i might pick one up for my girls car. from what you guys are saying it seems ok price finally popped up. $189 thats what makes me think it's junk. and there out of stock. another $50 and.you Can get some awesome used amps. p pass jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
dubtuner98284 Posted April 21, 2014 Report Share Posted April 21, 2014 I have to kick in my 2 cents here. I personally run PPIs sister company Power Acoustik. When I was looking for an amplifier, I was concerned with size, price, and output. I picked up the Razor RZ-2300D and have been happy ever since. I also spent less than 100 bucks shipped. It is tiny, efficient, and does everything my audio system requires. PPI and PA had a bad reputation for a little while, but I would not hesitate to use their equipment since the parent company picked up Soundstream. I don't know for sure if PPI is being built to the same quality control standards as the other two, but my PA is every bit as good as anything I have picked up in the higher price points. Cheaper does not always mean cheap.I'm sorry but Power Acoustic amps suck plain and simple. A RF 300 watt amp would walk all over a power acoutic 2000 watt badged POS and it wont wreck your electrical. The Razor RZ-2300D has 50 amps of fusing and is recommended to run on 8 ga wire. 1400rms watts my ass! Good luck getting 500 watts out of it if its stuck by lighting! That's funny, because I just got 42.5 volts at 56 amps draw. That equals 2252.5 watts. Assuming rms is roughly half of that, it sees 1126.25 watts. For an amp that is seeing less than 1% distortion, I would say that its no POS. I already knew that I would not see all of the expected power unless it was as you say Struck By Lightinin, but over 1100 RMS on a hundred dollar amp is great. That's less than .10 cents per watt. As for overheating, shutdowns, or general failures, I have had none, and I run my system at full tilt a lot. I don't know if they changed something, but my power inputs are 4AWG and not 8AWG. Link to comment Share on other sites More sharing options...
deathcards Posted April 22, 2014 Report Share Posted April 22, 2014 That's funny, because I just got 42.5 volts at 56 amps draw. That equals 2252.5 watts. Assuming rms is roughly half of that, it sees 1126.25 watts. For an amp that is seeing less than 1% distortion, I would say that its no POS. I already knew that I would not see all of the expected power unless it was as you say Struck By Lightinin, but over 1100 RMS on a hundred dollar amp is great. That's less than .10 cents per watt. As for overheating, shutdowns, or general failures, I have had none, and I run my system at full tilt a lot. I don't know if they changed something, but my power inputs are 4AWG and not 8AWG. only 2 ohm stable 2x25 amp fuses signal to noise ratio 70db alpine mrx-m240 175amps of inline fusing 1ohm stable puts out 2400 @ 2 ohms Signal to noise ratio 108db power acoustik works with genies and lanterns skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
slowfkncar Posted April 22, 2014 Report Share Posted April 22, 2014 I have to kick in my 2 cents here. I personally run PPIs sister company Power Acoustik. When I was looking for an amplifier, I was concerned with size, price, and output. I picked up the Razor RZ-2300D and have been happy ever since. I also spent less than 100 bucks shipped. It is tiny, efficient, and does everything my audio system requires. PPI and PA had a bad reputation for a little while, but I would not hesitate to use their equipment since the parent company picked up Soundstream. I don't know for sure if PPI is being built to the same quality control standards as the other two, but my PA is every bit as good as anything I have picked up in the higher price points. Cheaper does not always mean cheap.I'm sorry but Power Acoustic amps suck plain and simple. A RF 300 watt amp would walk all over a power acoutic 2000 watt badged POS and it wont wreck your electrical.The Razor RZ-2300D has 50 amps of fusing and is recommended to run on 8 ga wire. 1400rms watts my ass! Good luck getting 500 watts out of it if its stuck by lighting! That's funny, because I just got 42.5 volts at 56 amps draw. That equals 2252.5 watts. Assuming rms is roughly half of that, it sees 1126.25 watts. For an amp that is seeing less than 1% distortion, I would say that its no POS. I already knew that I would not see all of the expected power unless it was as you say Struck By Lightinin, but over 1100 RMS on a hundred dollar amp is great. That's less than .10 cents per watt. As for overheating, shutdowns, or general failures, I have had none, and I run my system at full tilt a lot. I don't know if they changed something, but my power inputs are 4AWG and not 8AWG.Wait,you are getting 1100rms @ >.01% thd through two 25a fuses? If you can post a vid of that clamp you will be one lucky guy with 180% efficiency at 2ohms Link to comment Share on other sites More sharing options...
TRTC360 Posted April 22, 2014 Report Share Posted April 22, 2014 83 dollars for those c3s is a steal. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360 Link to comment Share on other sites More sharing options...
deathcards Posted April 22, 2014 Report Share Posted April 22, 2014 http://www.sonicelectronix.com/item_38335_Precision-Power-PPI-P1000.1.html not gonna lie i feel like this amp isn't showing its true colors 14.4 @1ohm 1000 rms factory watts 12v @1 ohm 785 rms factory watts .02% distortion 3 x 40amp fuses signal to noise 106db skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
Aj11 Posted April 22, 2014 Report Share Posted April 22, 2014 1100w on 4g hmmm anyone gonna raise the flag? just find it odd that my 60.4 takes 4g and this "1100w" amp takes 4g jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
n8ball2013 Posted April 22, 2014 Report Share Posted April 22, 2014 Myaq 1200 is 4 gauge its good to about 1500 watts ppi is owned by soundstream. So if middle of the road might make rated but probably wont amps are your thing have at em THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
smashedz28 Posted April 22, 2014 Report Share Posted April 22, 2014 I have a chrome ppi power class 4800 (4 ch, 800watt). Last of the good old school ppi IMO. Link to comment Share on other sites More sharing options...
