Jhunt94 Posted April 25, 2014 Report Posted April 25, 2014 If you have the battery ground and the ground from the alternator in the exact same place wouldn't that almost be the same as having a ground from the alternator to the negative on the battery? 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
SnowDrifter Posted April 25, 2014 Report Posted April 25, 2014 If you gained by going alt case to battery negative, your other grounds are lacking and might need to be re-evaluated Just saying ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
AvionicsTek Posted April 26, 2014 Report Posted April 26, 2014 If you have the battery ground and the ground from the alternator in the exact same place wouldn't that almost be the same as having a ground from the alternator to the negative on the battery? Yes. You might improve your resistance between the two by a few milliohms by going directly from the alternator to the battery, but it will not improve anything either audibly or performance-wise over having your battery, alternator, engine block, and car/truck floor properly bonded to the frame of the vehicle utilizing the method I described in post #20. The same method we use to bond highly sensitive communication, navigation, and radar systems on aircraft.
dharris2488 Posted May 17, 2014 Report Posted May 17, 2014 Is the alt's rectifier a full wave or half wave rectifier? I believe it's a flux capicitor... hahahaha i know. Mechman specifically told me to run another 1/0 from alt casing/bolting point to negative batt post. I'm running close to 14volts now. So, I suppose I did a Big 4... Whatever, it works and I don't drop voltage too bad anymore. I was losing my mind before this run of wire... Maybe it's Mechman specific, but I doubt it. 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
dharris2488 Posted May 17, 2014 Report Posted May 17, 2014 If you have the battery ground and the ground from the alternator in the exact same place wouldn't that almost be the same as having a ground from the alternator to the negative on the battery? That's how I have mine. Alt ground to neg, neg batt to chassis, engine block to neg battery, and of course the alt + to batt+... If this is wrong, someone let me know please. I've checked resistance and the most I have is .2 from alt casing. My chassis ground is .1 and engine block ground to neg batt is .1. I suppose all is good.... 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
