The big 3 upgrade should be called the big 4
When I did mine I went with three ground points. One from battery to frame to block, then one from battery to lower alt bolt.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
No reason to run alt casing to front battery. That's not where the bulk of your current will be flowing from. Unless you like to charge a dead front battery every time you drive your car or something.
I have mine does as follows:
Alt positive to battery
Alt casing to strut tower
Battery negative to strut tower. Alt and battery both share a common ground
to me this is the way it should be done. I would prefer frame instead of strut tower but that is kinda application specific.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
My car doesn't have a frame :twirl:
Exactly why I said application dependant. Some cars its a better option some it isn't.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
same here alt to +batt,-batt to fram,-batt to block with this I have a t1000bd amp on stock batt and alt an I just recently reclamp all my lugs and got the wire brush to them also, voltage dips 10.5-11v
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
There is no one way it should be done. There's a couple options. All that's necessary is to complete a circuit, it's as simple as that.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
