New to the SQ game
crw092782
Sony MEX-N5000BT
http://www.sonicelectronix.com/item_75015_Sony-MEX-N5000BT.html
Receiver Size
Single DIN
Faceplate Security
Detachable
Motorized Faceplate
Yes
Remote Control
Yes
Peak Power Output
55 watts x 4 channels
RMS Power Output
17 watts x 4 channels
Preamp RCA Outputs
3 Pairs (Front, Rear, and Subwoofer)
Preamp Voltage
2 volts
Built-In Equalizer
10-Band
Display Color
35,000 Variable Colors
CD Signal-to-Noise
120 dB
CEA-2006 Compliant
Yes
2004 Pontiac Vibe Build
Sony MEX-N5000BT
JBL P660C x 2
Sundown Audio Zv4 18
Crescendo BC2000D
Crescendo S800/4
Execution Audio 0 AWG Wire
Sky High Car Audio RCA's
Toolmaker Terminals
XS Power D1200
DC Power 240HP Alternator
Viper 5706
Wow, that did not copy and paste well at all. lol
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Lacks time alignment and pre-out voltage is low. How do the new Sony's sound? I moved away from Sony because I didn't like the slight high frequency distortion they had.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
I've been happy with it thus far, but it is on stock speakers. It does have a time alignment feature on it though. I was playing with it a little when I installed it. I'll have to read up on it to figure out exactly how it works.
What head unit would you recommend? I got it from Sonic Electronix so I have plenty of time to exchange it for something else.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Voltage out doesn't mean anything for sound quality.
Some of the most high performing home audio sources can put out well below 1V.
The source in kirill007's avatar only puts out 0.25V.
Time alignment can be fixed with an external processor.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
What kind of signal processor should I be looking in to?
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
The more pre-out voltage you have, the better chance to introduce noise into your system.
1 - 4 volts is more than enough.
With your budget, I would go for a better headunit at a later date. This headunit should be more than enough to get you started.
I run the Kenwood DNX9980HD.
I've always been curious about that train of thought. Wouldn't you distort off the head unit power before the rca's output distorts to the amps?
Not sure what you are getting at brother ?? Are you asking if you can use the radio outputs and RCA outputs at the same time ??
Sorry I think I was mashing two concepts together. I know you can use speaker outputs and RCA outputs at the same time. I guess my question is wouldn't you clip from head unit power before rca's run through an amp because of the RCA's having a higher clip/distortion point.
I have seen it suggested quite a few times to run the rears off an aftermarket head units speaker outputs. Then you would use the RCA out's from the aftermarket head unit to bi-amp some components or run all 4 channels of an amp up front.
Just to finish this, yes all that I have played with the internal amp will clip before the RCAs. The reason to run the rears off the head unit is that you really don't want the rear fill being very loud. If you can hear the back and know it is the back then you need to turn them down. So you will fade to the front and the rears will never really get loud enough to clip anyway. Those are my thoughts on that. I even left my rear speakers stock because I am usually the only one in the car and front stage is all I care about (and sub stage of course). But thats why, no need for them really.
I think that's backwards. I'm not saying your dumb, or even wrong, I'm just saying this is how I understand it:
Given two identical wires run in the same environment, the same noise will be introduced. Lower voltage will be more affected by it because the amp will have to amplify the signal more to get the same output, thus the noise is amplified more as well. Therefore higher voltage is better. If you are using a balanced signal it will not be as big of an issue. Of course if you are running balanced that means you have some fairly high end equipment and might as well not skimp on a lower quality deck or processor that puts out low voltage. Does that make sense?
Personally I would go for 4 volt pre-outs
The amplifier will do EXACTLY what you tell it to do, and it's job is to amplify the signal injected. Nothing more.
(I work with broadband coax amplifiers every day) ...
Yes, if you give too low of voltage ... it will cause problems and not give out the correct output.
However, it will not "introduce" noise to the system.
But if you give the amplifier too much signal ... You will overwork the input stage of the amplifier. In return, introduce noise into the system by raising the noise floor and decreasing headroom. This can be also know as Distortion ...
and to be honnest, i'm not sure why you are disagreeing with me when I said "1 to 4 volts" would be fine ???
I've seen PLENTY of SQ systems using 2 volts with no problems ...
When it comes to SQ ... You don't want to get the absolute MOST out of your amplifiers, You want them running at their BEST power levels without creating distortion or noise. Which is why you normally see SQ vehicles running very LARGE amplifiers to the point if you crank up the gains ... you will melt the components sets.
Like me ... I'm running 1,100 watts "True" RMS of Class A/B power to my Front Stage alone. Which is a 5.25" component set and a pair of 10s ...
  • Who's Online   1 Member, 0 Anonymous, 1936 Guests (See full list)
