Kyblack76 Posted April 24, 2014 Report Posted April 24, 2014 Don went from BTL's to the SP4. After a port mod, "its night and day dude" Was what i got back. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted April 24, 2014 Report Posted April 24, 2014 less than 3 weeks from now, i will have a 3500 at .7 on each of mine. Daily, and a REAL 3500/more. And, im not worried in the slightest. In my opinion, the team may take a bit more power, daily, but, they both have the same exact "weak" spot. EDIT- i know of as many team subs that have failed (if you include AA) than the sp4 in the same manner. (also, the failure rate on BOTH/ALL drivers is lower than any other maker, im just bringing a point up) Now that there is NO mechanical failures, ..... well, you know where the weakness now lies. Its the same for both driver IMHO. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
baron_of_bass Posted April 24, 2014 Report Posted April 24, 2014 less than 3 weeks from now, i will have a 3500 at .7 on each of mine. Daily, and a REAL 3500/more. And, im not worried in the slightest. In my opinion, the team may take a bit more power, daily, but, they both have the same exact weak spot. EDIT- i know of as many team subs that have failed (if you include AA) than the sp4 in the same manner. (also, the failure rate on BOTH/ALL drivers is lower than any other maker, im just bringing a point up) Now that there is NO mechanical failures, ..... well, you know where the weakness now lies. Its the same for both driver IMHO. What's the weakness? Team Bass-Hz
Kyblack76 Posted April 24, 2014 Report Posted April 24, 2014 less than 3 weeks from now, i will have a 3500 at .7 on each of mine. Daily, and a REAL 3500/more. And, im not worried in the slightest. In my opinion, the team may take a bit more power, daily, but, they both have the same exact weak spot. EDIT- i know of as many team subs that have failed (if you include AA) than the sp4 in the same manner. (also, the failure rate on BOTH/ALL drivers is lower than any other maker, im just bringing a point up) Now that there is NO mechanical failures, ..... well, you know where the weakness now lies. Its the same for both driver IMHO. What's the weakness? For me? Lifting them into an enclosure....... Ive seen NO weak spot in my application, spite the fact i cant give them what they want power wise...... Yet SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
baron_of_bass Posted April 24, 2014 Report Posted April 24, 2014 less than 3 weeks from now, i will have a 3500 at .7 on each of mine. Daily, and a REAL 3500/more. And, im not worried in the slightest. In my opinion, the team may take a bit more power, daily, but, they both have the same exact weak spot. EDIT- i know of as many team subs that have failed (if you include AA) than the sp4 in the same manner. (also, the failure rate on BOTH/ALL drivers is lower than any other maker, im just bringing a point up) Now that there is NO mechanical failures, ..... well, you know where the weakness now lies. Its the same for both driver IMHO. What's the weakness? For me?Lifting them into an enclosure....... Ive seen NO weak spot in my application, spite the fact i cant give them what they want. Lmao hit the weight room, you actually had me thinking there was a weak point to the drivers themselves lol. Team Bass-Hz
n8ball2013 Posted April 24, 2014 Author Report Posted April 24, 2014 Realistically at .5 they should do about 3500 or so. Upgrades in power could always happen as well THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted April 24, 2014 Report Posted April 24, 2014 Realistically at .5 they should do about 3500 or so. Upgrades in power could always happen as well IMHO, .... perfect for a daily, that will do it at show, a comp,....... demo all day, all night. I dig a reliable rig, and system. Beat it like it owes you money, push it, here and there even, and .......... and then, do it again. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Swordlordboy1234 Posted April 24, 2014 Report Posted April 24, 2014 OBI with the lincoln on here has 4 SP4 15's.. He just went from 4 saz 2k's to 4 AA3800's. Don't know what ohm load. I assume 1ohm. Not sure what voltage he runs. He said he can no longer play down into the 17hz range. I think he is playing low 20's fine though still. Tuned to 28. Not sure box specs. But he said they love that kinda power. Just do the obvious things like don't clip and good voltage. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
n8ball2013 Posted April 24, 2014 Author Report Posted April 24, 2014 Thats where im going. The 95s are nasty but I have to be very careful what I play. I knew id be stretching them bjt didnt think itd be as bad. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted April 24, 2014 Report Posted April 24, 2014 All Obando did was basically quad the power. He loves it...... And the drivers do to. Also, the Fi coil options on the big boy subs are .7 or 1.4 . Keep in mind when ordering...... (i love the thought of doing one per, at .7. im fucking pumped) SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
