No, they're getting primed heavily to bury that factory texture stuff and sanded down flat in the primer stage ;)
The pin holes will be gone before primer is laid :D
Well, damn.. Ok then. This is why I leave most the fabrication stuff for you :P
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I finished my plate relocation. With a pair of 1.5" Corner brackets, #10 sheet metal screws, #10 bolts and nuts, and my drill.. It's done. Only look like 5-10 mins.
No, I did not drill into my bumper. I drilled into my crash bar on the bottom.
8D3C1657-0119-412E-A5FE-2E7959D5DB44_zps
7A0531B3-7E3E-4F6B-B0BB-FA07A5954CA4_zps
LMFAO so true
:blush:
^^ B)
Top is using the OEM bracket
7C275F0F-C7A6-420D-A6D6-3B04C12F2B73_zps
Bottom is after
8F7C1304-B507-4B08-B3E9-97D056A29F64_zps
If only I could smoke the bottom...
Also, I finished the ports. On the inside, I used 2 part plastic epoxy. On the outside, I used amazing goop (I know). On both, the inside and outside, I went over with some gorilla tape. She's sturdy for sure!
Ports and subs are installed.
Subs are D1. Each sub has a coil wired in series. I see 2.1 on one sub, and 2.2 on the other.
Then, the 2 subs are wired in parallel.. I see 1.2 ohms at the end of my 8awg to my amp. Looks good to me.
I'm happy.. Also doors are in the gone stretch. Hopefully they'll be shipped out in 2 or 3 days.
If I went in circles in this post.. My bad.. I'm a bit.. Yea...
LMFAO so true
:blush:
One more hit with falling putty on a couple spots and then the final prime and paint.
killer job like always -cleansierra, if i knew you did doors i would of shipped you mine lol
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
I wouldn't have time for your doors if you did ship them "Kermit". I'm not going to make it a habit to do doors for others.
shhhhhh dont same my real name here ..... lol
2010 Mazda 3
*Rebuild Time*
^^^ lmaoo what troll
2010 Mazda 3
*Rebuild Time*
I've been insanely busy, but here's an overdue update..
I got the subs playing last Saturday morning.
All amps turn on, along with the 3sixty. All channels have output too. Woot!
My doors/pillars aren't done, so I'm just using the factory rear speakers for the time being.
Now, with these (2) 3" ports.. There's ZERO port noise. Whereas, the single 4" port had noise.
From 32hz up, it pounds. The mid 30s - mid 40s straight up SLAM!
I'm tuned to 35ish hz, and am strong down to 32. I can play 30 and 31, but it's quiet. Under that, it straight up unloads.
My box designer and I figured this would happen though. I would extend my port, but they're as long as they can be.
My only other solution is removing the 1/2" wood I added to the inside of my box. I added 4 layers to shrink my box.. But may take out a sheet or two to lower tuning. I just hope that the internal volume doesn't raise too much.
I still need to overview my box sketch sheet and specs that I drew up when I built it. All should be good though. Meh, I don't have many songs under 30hz. Ill test, and test.. I guess.
Now.. Voltage story.. Well.. Fuck. Lol. For the FIRST and one of the few times, I was able to get my voltage under 13.7 at idle.
Makes me want to throw in the 2nd 3500 now lmao
But I have solid plans for the future. I have 2 plans.
LMFAO so true
:blush:
