hydraulic crimper
so all of my lugs on all my wires are either soldered or very very ghetto crimped by using a hammer and a steel pin. so im going to get some lugs from skyhigh and a crimper
will skyhigh 1/0 lugs work well with my knu cca 1/0 and will this crimper be enough to do what i need it to
http://www.ebay.com/itm/8-Ton-Hydraulic-Wire-Terminal-Crimper-Battery-Cable-Lug-Crimping-Tool-9-Dies-/390680393699?pt=LH_DefaultDomain_0&hash=item5af65db7e3
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
yeah i got the 16 ton one. Damn thing works damn good.
If it's worth building, it's worth over building.
what do you guys use for shca 2/0 ima asume the 2/0 for the 5 ton will not fit although it may work?
The 16 ton should work for the 2/0 I use one of the smaller dies for my skyhigh 1/0. There are some big dies in the kit.
I have the 16 ton almost identical if not identical to that one linked above and I have and use SHCA 2/0 OFC and the dies go even bigger than that. You will have no problem. They go pretty small too. I know I have used them for 4 ga. wire 3 different brands of OFC and there were smaller dies yet. I love having my crimper.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Hey just curious just ordered the 16 ton does the dies go down small enough to crimp Shca 8 gauge lugz
I can't believe how hard it is to find a battery cable crimps at a local store. I tried Menard's, Fleet Farm, Auto zone, O'Reillys, True Value, and etc.. Only place that had one available was oriellys and they wanted $349 for the long handle hydrolic one and $58 for the dye type you hit with a hammer! What a joke! I'll just have to solder or borrow one from my old work. (Be nice to have my own though).
97 Buick LeSabre with stock 140 amp alternator
XS Power D3400 (under the hood) using pdb distro blocks
Big 3 done with 2/0 ga welding cable
Alpine CDE-HD149BT head unit
CT Sounds Meso 6.5" components
CT Sounds 60.4
CT Sounds 1400.1
Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs)
Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders)
Connection BT2 & BT4 550 (Audison) RCA's
Bunch of Mojo Mat
Or just order online.......... Lmao.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
