[email protected] Posted May 13, 2014 Report Posted May 13, 2014 wassup boyz!! i just got myself a nice soundqubec hds315 dvc4 for my 4runner...currently,it is running on my alpine mrp-1000 (1000wrms at 2ohms) i know those sub are up to 1200wrms and can handle a little bit more...so im looking for an amp that will match it perfectly... for now,i only have 1 sub,but im looking to add an other one...i think i can set those 2 sub dvc4 to 1 ohm,so i need an amp that will give me +/- 1500wrms at 2ohms and 2500-3000wrms at 1 ohm...and i don't want to spend more than 500$ on that... currently,i have 2 amp in mind... http://www.cafr.ebay.ca/itm/SOUNDSTREAM-TA1-3000D-AMP-BASS-6000W-MAX-SUBWOOFERS-SPEAKERS-TARANTULA-AMPLIFIER-/131188885955?pt=Car_Amplifiers&hash=item1e8b7789c3&vxp=mtr&_uhb=1 and http://www.cafr.ebay.ca/itm/New-Soundstream-RUB1-2500D-2500-Watt-Rms-Monoblock-Amplifier-Car-Audio-Car-Amp-/301177521818?pt=Car_Amplifiers&hash=item461f94469a&_uhb=1 im not a soundstream nuthugger,but it seems that's the only amp that may fit my needs now and in the future... what you guy's think about those amp? and do you have a better option for me? note that im in canada,so shipping is kind of important for this purshase here my sub:http://www.soundqubed.com/HDS315_p_229.html thank you for your help!!! 2x SSA XCON 15'' 2 basworx 3000.1d 1 kinetik 1800 & exide 85amph skyhigh 1/0 all-around Grimreaper spl team co-president
Ahmed Johnson Posted May 13, 2014 Report Posted May 13, 2014 What is your max budget? I'm pretty sure you saw that SQ has a 2200 watt amp which is perfect for those.
[email protected] Posted May 13, 2014 Author Report Posted May 13, 2014 500$... those amp are rated 2200w at 1ohm, and 500w at 4ohm....and for this summer,it will be run at 2ohms...i just don't know how much this amp can give at 2ohms....and for the same price,soundstream seems to be a little more powerfull... anything else? 2x SSA XCON 15'' 2 basworx 3000.1d 1 kinetik 1800 & exide 85amph skyhigh 1/0 all-around Grimreaper spl team co-president
poorfish88 Posted May 13, 2014 Report Posted May 13, 2014 SQ 2200, is a much better amp IMO. I'd not go Soundstream, in fact the SQ is the cheapest amp I'd run. I run SQ2200 now and it's worth the cash.
wccfan12 Posted May 14, 2014 Report Posted May 14, 2014 Get another 15 then get the SQ 2200 and it would be a perfect match imo. You're not really gonna notice a difference on just 200 watts more rms if you're just trying to tune for the woofer's max rms rating. I wouldn't run much more than rated to these too they'll last way longer if you just run rated power. THE ANTHRACITE DYC CRUISER -Fully dipped anthracite grey pt cruiser -4 skar vvx 12's (version 1) -Mechman 240 amp alt -Big three in Cadence 1/0 -1 deka intimidator g31 blacktop under the hood -1 C&D 140ah Batt & 1 C&D 55ah batt in the rear -Re audio/soundstream mids and highs -Hifonics Zues 600.4 -DC Audio 3.5k
Kyblack76 Posted May 14, 2014 Report Posted May 14, 2014 Ns1 at .25 SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
jarrius Posted May 15, 2014 Report Posted May 15, 2014 The sq amps are better then sound stream IMO. The 2200 would be my choice. Edit: but before you buy any amp you need to take a look at your electrical and make sure it can handle the amp 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
john253a Posted May 15, 2014 Report Posted May 15, 2014 There is nothing wrong with the amp you have Your going to drop $500 for 200rms You will see no didferance in the way it performs Spend that 500 and get the hdc315 or 4 Then get a bigger amp hds3 q1-1200 @1ohm Hdc3 q1-2200 @1ohm Hdc4 q1-3500 @1ohm It's that simple 1000 to 1200 next to nothing You'll see more if a gain in a new correct built box
[email protected] Posted May 20, 2014 Author Report Posted May 20, 2014 i think im gonna go with another one of those hds315,and hook it up to the sq2200... is it ok to link 2x dvc 4 ohms to an 1 ohm amp?will this fry everithing of it will be all ok?? for the electrical system,i have 0/1 everywhere,an 200amp battery isolator with a power-sonic battery(55amp/h)...planning on adding a second one... do i need ho alt? 2x SSA XCON 15'' 2 basworx 3000.1d 1 kinetik 1800 & exide 85amph skyhigh 1/0 all-around Grimreaper spl team co-president
