Any tips on building a box in my trunk?
So one of the guys on here helped me out and gave me a nice box design that im gonna be building inside my trunk. This is my first time building a box inside my trunk im sure its not that much harder but the only thing im woundering about is how to screw everything together ive seen kreg joints being used and they look good and all but for 130$ for only a one time use doent seem to worth it and ive seen people use angle iron. Any help would me greatly appreciated
Use the kreg cleansierra linked to, put plastic down in your trunk to catch any random glue. Pre assemble the box and drill all of your holes outside the trunk, take it apart and glue and assemble it on your trunk and prepare for a sore neck and back the next day...Lol
Me and a buddy built a box in his trunk for 2 15's. Work well and is a solid box. Like said pre assemble everything before hand. For us we had a right angle drill attachment which helped a lot. We also used lots of brackets on the inside of the box along with lots of glue and sealed if all up with silicone. If you can build the box in 2 parts and just assemble the two inside of the trunk do that.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
I helped out with a trunk build for an HDC3 18 in an 02 corolla, we used tounge and groove joints and pre built the box outside the car, and since it took up almost the entire trunk we used angle iron on the inside in the places we couldnt get the drill in to from the outside and it worked pretty well but if you gonna use that method use tounge and grooves and seal all the edges.
Ive never heard of tonqge and grooves?
TandG_zps72abed56.jpgLooks like this.
While it's a very strong joint when done properly it probably isn't something you want to try on your first build due to the added difficulty. You would need a router (preferably a router table) and two different bits to make the joint. I think I would stick with the Kreg .
  • Who's Online   0 Members, 0 Anonymous, 2936 Guests (See full list)
