box for a skar zvx 15 v1.5
Im gonna make a box for my skar zvx15 and im hitting a speed bump in calculations.. heres what I got
30"wide
17"deep
18"high
3/4wood thickness
My probl3m is the port im trying as hard as I can to get it closest to 3ft^ and tuned to about 33hz .
But the port calculator keeps telling me I need a 30" long port is this right? I figured at 4.21ft^ it needs a 4"wide port 16.5"high but im getting 30" for length?
You need trunk space to get groceries and shit...bitches love groceries
After port and driver displacement it would put me at 2.8ft^ net but I think a 30" long port would tune it way too low
I can't take a look at it now, but I should be able to later today if no one else comes along to help you.
Builds:
add some polyfill your sub will never know the difference.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Id rather just build it right instead of adding polyfill..any input as far as whats the correct enclosure?
I checked your numbers. With your external dimensions your gross internal volume is 4.218 cu ft, a 16.5" x 4" port is going to remove about 1.3 cubes, plus another .15 or so for driver displacement puts you at around 2.75 cu ft net. With a 30" long port you are going to be tuned to close to 37 Hz.
Builds:
Thats retarded am I right? I knew this calculator wasnt calculating right..so it looks like youre pretty good with calculations. If I do a 3" slot port instead I figure around 22-23" port length will tune me around 38hz right? So how much longer does the port need to be in order to be tuned at 33-34hz?.
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, port clearance 3 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
If can't go bigger and use Joe X's design, try switching to a single 6" aero it will give you the lower tuning you want.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
