BigManAC Posted August 13, 2014 Report Posted August 13, 2014 That sucks about the alt man but hopefully the turn around will be quick. Congrats on the numbers. Hopefully at the next show in Atlanta I can improve mine a bit. Anyway awesome build and looking forward to seeing the finished product. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
boom50cal Posted August 13, 2014 Author Report Posted August 13, 2014 Thanks. We're REALLY close build wise. I'm hoping for a 146 at the next show i go to. After i get a 146+ another hd15 will probably be inbound. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
boom50cal Posted August 14, 2014 Author Report Posted August 14, 2014 Dipped my grill and added a legit rear frame ground tonight. At full tilt on most songs I only drop to 12.2ish when I used to dip into the 11s. Helped alot. Expecting my alt to be back next week. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
CaptainWhoosh Posted August 14, 2014 Report Posted August 14, 2014 Grill looks good! I have a set of the newer body style S40 R design rims that would look goooooood on this car . Any plans for a set of wheels/lowering? We don't do it for the glory.
boom50cal Posted August 14, 2014 Author Report Posted August 14, 2014 17's and bagging it next year. Not laid out on the unibody but low enough lol. Really just want the usefulness of airride to deal with the weight. I wish I could fit the newer S40 R wheels Even the stock S40 2.4i wheels...the 18's...my sisters 09 S40 has them. I would kill to have this car as a 5 lug On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
jcarter1885 Posted August 14, 2014 Report Posted August 14, 2014 Love the look of the grill and thanks for taking pictures showing grounds. Motivated me to go out and do a frame ground for the rear. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
boom50cal Posted August 14, 2014 Author Report Posted August 14, 2014 Love the look of the grill and thanks for taking pictures showing grounds. Motivated me to go out and do a frame ground for the rear. Didn't take much time at all. Thanks for the compliment on the grill! You're not far from me at all, next time I'm in Dallas I'm gonna hit you up, along with SRP. Have a little demo session somewhere On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
jcarter1885 Posted August 14, 2014 Report Posted August 14, 2014 Not a problem at all man, yeah im in Arlington with no sounds but wouldnt mind some demos at all. Tell me about it took a minute to pop off a grommet find a hole to run wire and a spot on the frame. Just sucks I tried to do it in 90 degree weather, but its done now. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
General Posted August 17, 2014 Report Posted August 17, 2014 The chassis of this car is only as good as 35mm2 (2 AWG) so it is better to run the cable all the way thought the car to prefent groundloops. Remember; The whole power suply is as good as the grounding. (something with chains and a weakest link) ______Some people and performances are beyond words______ Chairman of the foundation "Propper-Droppers Holland" 2012 Founder of the European delegation of `Propper-Droppers' 2011 Dutch Champion EMMA SQ MultiMedia advanced 2010 European Champion EMMA SQ experienced 5 channel 2007 Dutch Champion EMMA SQ experienced 5 channel 2007 BeNeLux vice Champion dB-drag street-A 2007 Dutch vice Champion dB-drag ministreet-sedan 2004 _________________________________________ Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass. The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
boom50cal Posted August 17, 2014 Author Report Posted August 17, 2014 The chassis of this car is only as good as 35mm2 (2 AWG) so it is better to run the cable all the way thought the car to prefent groundloops. Remember; The whole power suply is as good as the grounding. (something with chains and a weakest link) Where is your primary ground at? Also, where in the world is the engine ground at? Just that one ground helped pretty well but I do still need to do a to-front run, guessing to the front strut tower? On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
