Bad Amp?
SMZ2
I have an mb quart 4.125 and alt wine. I ran new wire everything. I have checked all the grounds, rcas, speaker wire, and fuses. After swapping out I still had noise. Then I swapped the mb quart with my old 2 channel and boom noise was gone. All the wire was still the same from the mb quart. Is the mb quart bad? I bought it lnib second hand. Am I missing something. Swapping and losing noise sounds like a bad amp to me. What do y'all think?
How is the contact poit for the ground connection at the vehicle/chassis? Was it scraped down to bare metal? Has rust/corrosion developed over time?
You say the 2-channel works fine, which I'm going to ASSuME the 2-channel is a less powerful amplifier and thus demanded less amperage. The ground connection wouldn't have to be quite as strong to support powering it.
I was looking at your build log and it looks real good, so i don't suspect this is a problem, but is your ground wire the same size as your power wire?
2002 Toyota Corolla
Pioneer DEH-80PRS
Soundqubed Q1-2200d
Soundqubed HDC3.118
Soundqubed Q4-120
Alpine SPR-60
Alpine SPR-60C
One thing I am thinking of, since some amps require different RCA technology. That you need to ground the RCA's.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
What type of surface was it mounted to.... I had a issue with a fosgate amp one time where it didn't like metal contact so I mounted it to a beauty board and never had an issue
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Are you talking single-ended input vs. differential? bc I personally have only heard of that causing distortion or muddy signals, but it is more then possible it could also create a ground loop, so in that case try using coax RCAs instead of twisted pair and see if it helps
2002 Toyota Corolla
Pioneer DEH-80PRS
Soundqubed Q1-2200d
Soundqubed HDC3.118
Soundqubed Q4-120
Alpine SPR-60
Alpine SPR-60C
  • Who's Online   0 Members, 0 Anonymous, 613 Guests (See full list)
