MrFree Posted April 2, 2012 Report Posted April 2, 2012 thank you sir R.I.P...99'Dodge Grand Caravan 03 Lancer Oz Big 3 HU-JVC KD-530 RCA's-rockerfosgate 41/2 inch Infinity mids Subs-(12's)2 Orion xtr124 Amp-Coustic600se battery-2 x stock, 1x Shuriken SK-BT20 Box-L-ported 3.562cubes@35Hz miscellaneous-stinger volt-meter, gain nob, (coming soon bass pro,eq,line drive) I dont have flex yet but damn I sound good,(coming soon....flex) Check out my HHR install Everything I install or build here:http://s1160.photobu...s/q485/MrBfree/ Also video's of my Car with the new box.http://www.youtube.c...lentGyge/videos
BassMunky Posted January 24, 2013 Report Posted January 24, 2013 what the rule of thumb for facing the port to the back? How much space do you need from the wall to the port? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
CJSmith Posted January 24, 2013 Report Posted January 24, 2013 My setup is subs up, port back. But then again, I have a good 2 feet between the top of my box and my roof, and my port is around 10 inches from my back door. I've had better experience with this application, than my previous subs back, port back. IIRC it was about .6 db louder with subs up, port back. There are alot of variables to consider and every build is different... The best way to find out is trial and error IMO. *Rebuid in progress*
BassMunky Posted January 25, 2013 Report Posted January 25, 2013 what is your ride? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 25, 2013 Report Posted January 25, 2013 My setup is subs up, port back. But then again, I have a good 2 feet between the top of my box and my roof, and my port is around 10 inches from my back door. I've had better experience with this application, than my previous subs back, port back. IIRC it was about .6 db louder with subs up, port back. There are alot of variables to consider and every build is different... The best way to find out is trial and error IMO. ride? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
AllanLuberda Posted January 27, 2013 Report Posted January 27, 2013 its the way my system always sounded louders id vouch
Donnie Hutcheson Posted December 25, 2017 Report Posted December 25, 2017 Subs up , port back. Absolutely what works best for getting loud . ? %
anr102990 Posted December 25, 2017 Report Posted December 25, 2017 I have personal experience in both my old vehicle ( a 95 4 door blazer) and in my sisters 2005 pathfinder, that subs up and port back always sounded better and seemed to be louder than subs back and port back. Just my 2 cents. Good luck
ShadeTreeMechanic Posted December 25, 2017 Report Posted December 25, 2017 I have mine subs front port front to keep it from killing my tailgate. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
8ten8 Posted December 27, 2017 Report Posted December 27, 2017 Today, just for shits, I flipped my single 15 in a 6th - ports up...yuck! What was once a 6th tuned to 55 and 25, turned into a single slot tuned to 34hz. Rolled off on both ends dramatically.
