Is it bad to run two different subs together??
Currently I have a jl 10 w1v2-4 and a jl 10 w3v3-4 running together powered by a mono 500 watt amp. The w1 is rated at 300 rms max while the w3 is rated at 500rms max. When bass hits in car it seems lacking compared to when I had two W1s installed. One of my W1s finally kicked the bucket after 8 years but the other one is still kicking strong. After swapping out busted W1 for new W3 it seems as though the W1 is hitting way better then the new W3 on the other side. Is this because the W3 requires more power then the W1 to perform. Im currently in the middle of upgrading the system just waiting on money. My plan is to get rid of W1 and 500 watt amp and upgrade to another W3 and a JL audio JX1000/D amp in the near future.
It's not recommended, though it can be done.
Part of the reason the older W1 is hitting harder is due to the W3 being new and it's suspension being stiff, after a couple weeks of use, it will loosen up na d play louder and deeper.
Oh, and you'll likely get more cancellation/peaks between the two different subs than two same model subs. If you are running the subs in a shared chamber enclosure, running to different subs is not a good idea.
chamber isnt shared ... the box separate the ports
Don't do it
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Its ghetto. Does that count
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Not even once.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Not a good idea
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
"Is it bad to run two different subs together??"
Bad? no.
preferred, recommend, common? no
It will not sound near as good as it could/should. Almost everyone doesn't do this, and no one should
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
