Jay L. Posted June 28, 2014 Author Report Posted June 28, 2014 Blood pressure..........check..... So while the "BIG" alt is just cruising, the small one is putting out max amperage? I dont want to overwork either. My question has nothing to do with them turning on...
Kyblack76 Posted June 28, 2014 Report Posted June 28, 2014 Blood pressure..........check..... So while the "BIG" alt is just cruising, the small one is putting out max amperage? I dont want to overwork either. My question has nothing to do with them turning on... No they will both push what they can WHEN they are in demand. The "big one" one go boss, then the small.. what you will see, is BOTH doing work.. EDIT hold for vid SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted June 28, 2014 Report Posted June 28, 2014 Blood pressure..........check..... So while the "BIG" alt is just cruising, the small one is putting out max amperage? I dont want to overwork either. My question has nothing to do with them turning on... sooooooooo a big boy alt, and one that is smaller..... charging together, in harmony. "Neither will spit out MAX any thing, unless its demanded. WHEN it is in demand they will tug" You seem like the guy that "if i have a bigger BATTERY, will the voltage pull from here" type. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Jay L. Posted June 28, 2014 Author Report Posted June 28, 2014 Nope, your not getting it, and I'm not a "type" Refer to first post
Kyblack76 Posted June 28, 2014 Report Posted June 28, 2014 Nope, your not getting it, and I'm not a "type" Refer to first post NO your not getting it... refer to my post. The larger WONT do more "work" more than the smaller... TYPE? ment alt dude.. not you... lol. You.. you are lost. You know what? good luck dude... there are a lot of others that can help you.. Me? im done here. Good luck . EDIT- just dont post false anything SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Miguels Posted June 28, 2014 Report Posted June 28, 2014 both alts will work just as hard. the difference is one will be putting out 300 amps the other will put out 200 amps (numbers will differ) my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
TeamHT Posted June 28, 2014 Report Posted June 28, 2014 I really don't see what's wrong with OP's post. If you're not going to help with his question, just close the tab. Singer is a big boy, looking like a drake Jr. but for audio brands Tell me...does this smell like chloroform to you?
Jay L. Posted June 28, 2014 Author Report Posted June 28, 2014 You are either stoned, drunk, or both. Or need to be stoned, drunk, or both.
Miguels Posted June 28, 2014 Report Posted June 28, 2014 You are either stoned, drunk, or both. Or need to be stoned, drunk, or both. if you're talking about kyle.. most likely he is stoned and drunk my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Jay L. Posted June 28, 2014 Author Report Posted June 28, 2014 Miguels got it! Finally, someone coherent....so, one alt. getting overworked, while the bigger alt isnt. Now, is that bad?
