Car leaked oil and now my engine knocks...
If you dont use premium already, try a fillup with 93 or 91, whatever you got there.
Since Duck wants to get all technical, a true knock is a combustion related issue, not a mechanical one. Also known as pre-detonantion. Higher octane fuels can sometimes cure this.
cause rods never knock lol
So i just went through this recently. My car is known for rod knock and i have used thicker oil to where the knock is almost gone. I ran into the same problem you have, sadly it was my bearings and crankshaft. Take off your lower oil pan and check out your bearings just to check it out. No oil it usually ruins the bearings and over time it can ruin the crank.
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
Ticks are lifter noise and knocks are rod bearings.
A knock or a tick can be many things they are not just limited to rods and lifters. Just recently I worked on a Ford windstar for a friend it had one of the worst ticks you've ever heard. Anybody want to guess what it was? I'll give you one clue it was not a lifter but the noise was in the top end.
Stuck valve contacting piston?
Broken valve spring?
SMD Super Seller
My Feedback Thread
Just gave it a good listen. The knock (and I do say knock not tick) is as pronounced on the bottom of the engine as it is on the top. It is also loudest towards the back of the engine.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Pull the pan and check the connecting rods near the back of the engine first and see if you can feel any excessive play in them.
As long as you don't spin a bearing you'll get away with just replacing them with new stock sized bearings.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Likely a bearing. Might be able salvage it, depending on what bearings are available for the motor. You'd need thicker ones to compensate for the play created by damage.
You need to get the oil pan off and have a Mopar guy check the rod bearings for play.
SMD Super Seller
My Feedback Thread
  • Who's Online   1 Member, 0 Anonymous, 1434 Guests (See full list)
