Car leaked oil and now my engine knocks...
Could be a stuck lifter then. What oil weight do you run right now?
Little trick if you don't have a stethoscope: Grab a socket extension, press it to a part of the engine, ear next to the other end. See if you can narrow down where the noise is coming from
Also it appears to be coming from the top of the engine
You may be lucky, and the knock is just from the heads. But running it hard on low oil like you may have done, most likely caused damage in the low end as well.
SMD Super Seller
My Feedback Thread
well, normally a tap is from top engine and a knock is bottom engine, but all these modern engines sound kinda hollow anyway. Could be hard to tell unless you do like snowdrifter said
X2 you can also use a long screwdriver.
If you dont use premium already, try a fillup with 93 or 91, whatever you got there.
Since Duck wants to get all technical, a true knock is a combustion related issue, not a mechanical one. Also known as pre-detonantion. Higher octane fuels can sometimes cure this.
SMD Super Seller
My Feedback Thread
I would say a lifter tick. If you do 7 passes and that long of a drive without noticing any noise, chances are you pushed any oil that was equal to or above the rear main seal level out and that is why you didn't notice a leak before doing the drive and passes. It's possible you just have a stuck lifter. I would do the rear main, fill it up with an oil a weight above, and see if the noise is still there. Possible if you have a timing chain, one of the tensioners, guides, etc ran a little dry and ate up a bit of the sprocket teeth and/or a bit of chain causing a little slack resulting in the chatter you hear. One person mentioned running a synthetic blend, that wouldn't be a bad idea IF you already run synthetic. Switching over on a motor that is used to conventional after such a long time can cause more harm then good. Only time I run synthetic is if I rebuild a motor. Conv for a few thousand miles for break in, then switch to synthetic right away. Just my .02 cents though. Best of luck!
