shepherd92683 Posted July 13, 2014 Report Posted July 13, 2014 Given the equipment in my sig, what should be the amount of drop that I get? Currently with my amp I don't have a scope or dd1 so I matched gains as accurate as I could by input voltage and the clipping indicator on the bass knob. Before the clip light goes off it drops as much as 1v. When the clipping light is going it drops as much as 1.7v. It does not seem to change with or without my rear battery installed. I didn't think it should drop that much with what I'm running. 2017 Honda Accord Touring Build coming soon
justin0943 Posted July 13, 2014 Report Posted July 13, 2014 have you done the big 3 it helped mine from droping to 10v to 11.3v now on full tilt on stock batt and 90amp alt on a t1000bd 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
alaskanzx5 Posted July 13, 2014 Report Posted July 13, 2014 People on mobile can't see your sig so you should post your gear for us. I don't know what your running but most people are happy to stay above battery voltage. I personally on a total of 3400-3800rms I'll be happy to stay above 13v. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
shepherd92683 Posted July 13, 2014 Author Report Posted July 13, 2014 Can't do a proper big 3 on my vehicle because it has rvc but the wires that could be upgraded have been. If my voltage decides to float at 14.2, at full tilt will go down to 12.5 and if it floats at 13.6 then will drop to about 12. I have no answer other than the way rvc works for the change between the 13.6-14.2 voltage fluctuation. Equipment is: AQ 2200 BOSTON GT 4100 XS POWER D3400 KINETIK HC2400 MECHMAN 250A ALL STINGER HPM 1/0 2017 Honda Accord Touring Build coming soon
alaskanzx5 Posted July 13, 2014 Report Posted July 13, 2014 Talk with mechman and see what info they can give you on increasing voltage for your vehicle. 12v isn't bad. More is always better but that's not bad drop imo. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
TheMonolith2001 Posted July 16, 2014 Report Posted July 16, 2014 Well both your amps are rated down to 12v so they should be okay. Next I would check how the other electronics in the car will take it.
pioneerforlife Posted July 16, 2014 Report Posted July 16, 2014 As long as my amps are still on I don't care what my voltage is lol. no but seriously I would be happy with holding battery voltage. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
shepherd92683 Posted July 20, 2014 Author Report Posted July 20, 2014 What I'm trying to figure out is if the drop that I'm getting is what it should be or should it be less? Also is there a specific reason that with or without my rear Kinetik installed the drop is the exact same? 2017 Honda Accord Touring Build coming soon
