Taramps Amplifiers legit?
dharris2488
Quick question, are these Taramps amplifiers legit? I've got to run and I know I should research before I ask these questions, but I was hoping some of you might give me a little insight on these... The prices seem really good, especially for someone that has a regulated alternator. It appears I can get rated power at 13.4 volts? Looking at the HD5000.... Any insight is always appreciated!
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
IIRC the people who run them say as long as you give them plenty of power and don't go below minimum impedance rating they are fine.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
^^Yep, what he said.
They're not like Koreans, you don't need to wire below rated to make power, and you should not, they don't like it. You need to have strong electrical to run them or they like to go poof. Based on your sig, you would need to beef up your electrical if you wanted to run that 5k all out.
Do a search, there's been a couple tests. There's one here, and I know TFade threw one up on MAF.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
I've heard a lot of good things about them but similar to what I ran into w/ SD amps, they're pretty power hungry but do every bit of rated and some more.
2006 Hyundai Sonata Lx
- Alpine CDA-9885
- Rainbow CSX Comps
- (2) 12" Sundown Zv4
- Sundown 5K
- 4.6ft3 @ 33hz w/ 6" aeros sealed off in trunk
- 250a Singer alt, Kinetik 1400, (2) 2400s
- 150.4 @ Dash as of now
Power hungry? Not sure if srs
Efficiency? ha these amps are running laps around that
Considering I can run a Taramps 3k on a stock 150a alt, with a 65ah agm under hood and 1/0 welding cable, I'd say power hungry is incorrect
I've already made an review. Steve posted it on his facebook as well.
Have battery power, and never wire below impedance.
I posted an 157.8 yesterday with an single 8K at 3 ohms.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
not power hungry but they don't like low voltage.
F150:
Stock :(
Processor: DSR1
So, I need to update my sig. as i have beefed up my electrical a bit. Right now I have the 240amp Mechman and (3) 70ah AGM's (total 210ah, like that math? lol), and 2 runs of + 1/0 welding cable from front to back. To run the 5K, would it be suggested that one more battery be enough?
I'm currently running strapped Q2200's and on long bass drops, I've seen my voltage drop to 12.0. Would one more battery be good enough for the 5K? If not, I need to figure out a way to stabilize my voltage. Are UltraCap's the answer, or am I going down the wrong road? Are batteries the answer?
CT Sounds 4000.1D
(4) 8" PRV 8MB450's
Pioneer AVH-X4600BT
well
  • Who's Online   0 Members, 0 Anonymous, 775 Guests (See full list)
