adreano17 Posted July 17, 2014 Report Posted July 17, 2014 I have been troubleshooting for weeks now, so excuse my multiple posts as I narrow down the problem. I have an 2005 Acura TL that I have integrated a 4 channel amp in there. Therefore, there are many components in the equation and I have the factory amplifier still installed to boost signal for LOC. So this is what I CONFIRMED. I tested the voltage of the pre (factory) amp leads and the voltage of output of factory amp. And here are the results:Pre-Amp:wht/yel (Left Rear) .06-.07 VACorg/red (Right Rear) .06-.07 VACgrn/blue (Left Front) .04 VACgry/blk (Right Front) .03 VAC [spec is supposed to be 1v @ 40/40 while playing 1khz coming from headunit/radio]Factory Amp Output:Green: 2.3 VACPurple: 2.3 VACGrey: 7.7 VACWhite: 8.2 VAC__________________________________________________ __After passing through LOC:All channels no more than 1.8 VAC at the RCA coming out of the LOC I have the 4ch line out converter by PAC soem-4. I have adjusted the switches to RCA and Wired input, and Wired and RCA output. I think since it is a high signal coming into the LOC, I get the best output voltage when I have them both on RCA for input and output source, but it is still low. This is all causing my Aftermarket amp in the trunk to give very low output voltage even after adjusting gains up and down.Now the question is, why is my LOC diminishing the voltage by that much? Given my radio isn't at spec, but the LOC is looking terrible right now. IMO....note this is all conducted at 40/40 volume with 1khz test tone playing. Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
adreano17 Posted July 17, 2014 Author Report Posted July 17, 2014 Admin, if this should go in general, could you please move it? Thank you. Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
bigmizzle99 Posted July 17, 2014 Report Posted July 17, 2014 Why not try a different LOC like AudioControl ? Each model typically has a very wide range of Iinput voltage sensitivity (200mv-8v) and a high outyput voltage. I'm using a Cleansweep with OEM head unit and its strong Camaro SS Build Altima build 2.0 Altima build 1.0
adreano17 Posted July 17, 2014 Author Report Posted July 17, 2014 I don't have CleanSweep money bro. Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
mothra Posted July 17, 2014 Report Posted July 17, 2014 test your voltage at a couple of points of volume, most likely the factory amp has a plateau in the response. if so you'll need a DSP like the PS8 or 360.3 to get a linear response. if nothing changes, nothing changes You don't know what you don't know, till you don't know
bigmizzle99 Posted July 17, 2014 Report Posted July 17, 2014 Well, it doesn't have to be that model. Someone was selling a used LC6 on this forum. You can buy LC6 on amazon for around a $100. In this hobby, a hundo is pretty cheap. Camaro SS Build Altima build 2.0 Altima build 1.0
adreano17 Posted July 17, 2014 Author Report Posted July 17, 2014 test your voltage at a couple of points of volume, most likely the factory amp has a plateau in the response. if so you'll need a DSP like the PS8 or 360.3 to get a linear response. I don't get any RCA voltage at 30/40 volume for whatever reason. If I tap into the preouts of the factory amp, I get 0v even with it at 40/40. The system has worked fine before. One of my channels took a crap, now all these problems. Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
adreano17 Posted July 17, 2014 Author Report Posted July 17, 2014 Well, it doesn't have to be that model. Someone was selling a used LC6 on this forum. You can buy LC6 on amazon for around a $100. In this hobby, a hundo is pretty cheap. I know, but having purchased a brand new amp, LOC, and just ordering a new radio is alot of money for something that worked flawlessly a few months ago. Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
bigmizzle99 Posted July 17, 2014 Report Posted July 17, 2014 You say you ordered a new radio? Then your problem should be solved with the preouts of the new radio...yeah? Camaro SS Build Altima build 2.0 Altima build 1.0
adreano17 Posted July 17, 2014 Author Report Posted July 17, 2014 What If I just splice some RCAs from the factory amp output and connect them to the aftermarket amp? Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
