bass juggernaut Posted August 5, 2014 Report Posted August 5, 2014 I have a 2005 chevy silverado half ton, I'm doing a b pillar wall with 8 ten inch rockford p2d210s ran off of two rockford t1000's, and I was thinking about using a single 8 inch aero port with a depth of 6 inches long. The box dimensions are 38 high, 50 wide, 14 deep, total box volume of 9.85 cubes tuned to 34hz. Does anyone see any issues with my box design or have any additional input on anything about my box design?
tacomaguy1 Posted August 5, 2014 Report Posted August 5, 2014 only 5" of port area per cubic ft. on the small side even for an aero Team Flex Issues
bass juggernaut Posted August 5, 2014 Author Report Posted August 5, 2014 what should i be shooting for as far as port area??
mothra Posted August 5, 2014 Report Posted August 5, 2014 I never use a round port that is less than 10". I get port noise or chuffing all the time. You should look into increasing your port area to get a little more length. I'm not saying you will have port noise but it's too dependent on too many other variables. if nothing changes, nothing changes You don't know what you don't know, till you don't know
bass juggernaut Posted August 5, 2014 Author Report Posted August 5, 2014 what if i use more then one? or does anyone have any ideas so i can get my 9 cubic inches within 32-35hz?
tacomaguy1 Posted August 5, 2014 Report Posted August 5, 2014 2 would be 10.2" which would be a lot better there really isn't a rule to go by Team Flex Issues
Triticum Agricolam Posted August 6, 2014 Report Posted August 6, 2014 Two 8" ports would be about 100 sq in of port area, for what you want to do that should work well. They will have to be about 20" long though. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
CleanSierra Posted August 6, 2014 Report Posted August 6, 2014 Just go sealed if you plan on putting that many subs of that size and type. It will sound better than an enclosure with inadequate port area. If you want to go ported, start subtracting the number of subs you want to run, maybe run just 4-6 Im not the one you want to try to troll. Just a fyi for you.
alaskanzx5 Posted August 6, 2014 Report Posted August 6, 2014 For the money you would spend on those subs you can get 1-2 subs that will be louder and cleaner sounding imo. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
