Karlswinslow Posted August 8, 2014 Report Posted August 8, 2014 so I'm running a 15" power acoustic mofo on a hifonics brutus elite, i have a voice amp running about 2 10s / 2 8s / 2 6x9's 2 5" and about 6 tweeters. its a bullshit voice amp.. don't even know the name, autotek or something.. problem is, if i play my system hard enough for a little, the whole shit cuts off. and both amps cut off.. i checked the voltage upfront when its playing.. its at about 13 something... then checked the amps straight and when the music cuts it goes to about 4 volts.. i have only a yellow top and a 90amp alt.. any idea what that is? also... I'm running 2 x12's soon, what alt should i get and would 1 yellow top in front nd one yellow top in back be okay?
Noel989 Posted August 8, 2014 Report Posted August 8, 2014 4 volts? List all equipment your running Wire, speakers, electrical etc everything Build Log - http://www.stevemead...-cruiser-el-pt/
SIDE SHOW Posted August 8, 2014 Report Posted August 8, 2014 You hav an amp running 8 speakers and 6 tweeters?
Chris Strausbaugh Posted August 8, 2014 Report Posted August 8, 2014 Well if you're running 8 speakers and 6 tweeters off of one amp there's your problem right there. What's the ohm's on that like .0005 lol
Karlswinslow Posted August 8, 2014 Author Report Posted August 8, 2014 when the whole system cuts off, from the amps it drops to 4.. but from the battery it stays around 13. even when it cuts off.
bassaddiction Posted August 8, 2014 Report Posted August 8, 2014 what!!!!!!????? ur testing the wire at amp with dmm. is it a harbor freight multimeter lol or is the amps display meter say 4 volts what size wire is going in the amps and what ohm is everything
Karlswinslow Posted August 8, 2014 Author Report Posted August 8, 2014 its one of those harbor freight ones.. i believe 8 gauge to the voice amp and 4 gauge to the bass amp
bassaddiction Posted August 8, 2014 Report Posted August 8, 2014 its one of those harbor freight ones.. i believe 8 gauge to the voice amp and 4 gauge to the bass amp take rcas out of voice amp and see what voltage is
n8ball2013 Posted August 8, 2014 Report Posted August 8, 2014 take everything out before you burn your car down THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
