nathanb5533 Posted August 17, 2014 Report Posted August 17, 2014 is it bad when you have a duel voice coil sub for one of the leads on one voice coil to be broken what does this do and how does it effect my subwoofer? 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
philrab Posted August 17, 2014 Report Posted August 17, 2014 Like one of the tinsel leads broke. You have a dead coil. Throws off your ohm load, sub will not play to it's full potential, ect. Any chance its in a spot where you can fix it? 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Weigel21 Posted August 17, 2014 Report Posted August 17, 2014 Your (lets say, 1000RMS DVC 4 ohm) sub is now a SVC 500RMS sub and most of the T/S Parameters of the sub will change.
nathanb5533 Posted August 18, 2014 Author Report Posted August 18, 2014 Like one of the tinsel leads broke. You have a dead coil. Throws off your ohm load, sub will not play to it's full potential, ect. Any chance its in a spot where you can fix it? yeah but ill need a heat gun to remove the dustcap and a soldering gun, and a new tinsel prob replace all four and some glue and take out the old and add a new one to the voice coil? correct . Its broken right where it connects to the speaker wire 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
nathanb5533 Posted August 18, 2014 Author Report Posted August 18, 2014 Like one of the tinsel leads broke. You have a dead coil. Throws off your ohm load, sub will not play to it's full potential, ect. Any chance its in a spot where you can fix it? yeah but ill need a heat gun to remove the dustcap and a soldering gun, and a new tinsel prob replace all four and some glue and take out the old and add a new one to the voice coil? correct . Its broken right where it connects to the speaker wire also the spider has holes and rips, id do a recone if i new the model number but its like a 2001 american bass 6 ohms dual vc 15 inch vfl series and cants find it anywhere, plus the vc is smaller then it is now so i wont find the right fit 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
OrionStang Posted August 18, 2014 Report Posted August 18, 2014 Contact American Bass. Maybe they can help. If not, just bang on the one good coil. Won't hurt anything. SMD Super Seller My Feedback Thread
biscuitownz Posted August 18, 2014 Report Posted August 18, 2014 To answer your question. No it's not bad, you just won't be getting the full potential out of the sub.
nathanb5533 Posted August 18, 2014 Author Report Posted August 18, 2014 Contact American Bass. Maybe they can help. If not, just bang on the one good coil. Won't hurt anything. they do not carry my size voice coil because its 15 years old 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
REH Posted August 18, 2014 Report Posted August 18, 2014 15 year old, dual 6 ohm coils, ripped spiders and a torn tinsel? Instead of using/repairing I'd just put it up and keep it as a little treasure from the past honestly and find a replacement to use. While banging on the replacement you can search all cracks and corners of the web and hunt for the parts to fix it up if you want, but I doubt that'll be a quick process.
timc31610 Posted August 18, 2014 Report Posted August 18, 2014 PSI maybe? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
