Mini Cooper Wall Thread, Version 2
i want to see it done, what does it do on the mic?
im thinking about building a half wall in my 84 mini
84 austin mini
building a system for it currently
  • 3 weeks later...
i need to put a little fiberglass in one spot on the lower part of the drivers side piece, a part that isnt as hard as the rest of the panel, but its been raining everyday all day for the last few days here, so its hard to fiberglass/sand with everything wet...
Posted Image
Posted Image
Posted Image
Posted Image
messing around with ideas on how i should do the back..will be 3 amps total back here (the other 2 up front) so i think im gonna angle them like i have that template mounted at the top (represents a sundown 100.4) and then the 2 sub amps under that, with a trim panel fiberglassed all around it out to the weather stripping, like the front of the box is
Posted Image
Posted Image
Posted Image
fuck get this thing done already
:D
R.I.P!
(Nov-29-2009)
92 explorer
current build
What ever happened to the door trims?
They are sex :P
1994 Suzuki Vitara (Escudo)
[unreveiled Subwoofers] - 1,500Wrms, triple stack motor. 15" x 2
DD M1A x 2
10.5 cubes in a tiny car ;)
looks freaking awesome
"never drive faster then your guardian angel flies... good think my guardian angel drives a twin turbo ed beast"
"its time has come for those who are different to stand united"
  • 7 months later...
rise from the dead, because i want updates!
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
  • 3 weeks later...
gonna start working on this again soon..its been just sitting in my garage untouched
need some ideas.. almost done with the wall, needs a little more sanding on the sides of the trim panel then ill get it all covered once im completely done with all glassing and interior work.
over the last ~2 years, my suede headliner doesnt really look new with all the bondo and sanding and dust thats in it, i can clean it but id rather redo it, and this gives me the chance to fiberglass it how i want. im gonna cut it out and then fiberglass my a/c controls up there, as well as a little 7" screen i have to be used for a reverse camera. any other cool ideas i could put in the headliner? theres not much headroom so it cant be anything with a lot of depth.
the door panels are almost done, but i may delete at least 2 mids and 2 tweets out of each door due to the tight fit. i already have all the mids/tweets so i need to put those elsewhere. the top of the dash has a bit of room, enough to fit those 4 mids and 4 tweets glassed in firing up so im gonna do that, should be easy. its gotta be re-upholstered anyways so why not.
any other ideas? going to build a small console as well from the front "stack" in the middle (where stock hu/ac/controls were) to the start of the wall. itll be flush with the dash and house my 10.4" touch screen and computer (its a tiny ass computer lol) as well as my window switches, etc.
btw- when funds allow, new gear will be all IA (except the mids, although i know IA is working on mids but i still want to run my PA mids/tweets.)
4 20.1s, maybe 30.1s if they come out by the time im ready to buy
2 18" wardens
couple ia 6.4s for the mids/highs amps
deka 9a31 batts (around 6, ill be getting these shortly)
headliner will be suede again, wall will be black vinyl, the amprack for the IA6.4s below my subs will be black suede, seats will be suede, dash will be vinyl with suede accents, doors will be black vinyl along with the kick panels etc. and the console not sure yet, but probably vinyl with suede accents.
