Looking for advise I built a ported box tuned at 35hz in side the harley bag not really getting the performance I was looking for any suggestions maybe tune it at different frequency or different type of box any advise would greatly be appreciated
Better off making it sealed if its going to be facing into the open environment.
If you put a subwoofer enclosure inside of a sealed box you won't have much output except for some buzzing and vibration. You have to use the bag as an enclosure and month *MOUNT them facing in or out.
. I didn't explain it rite I guess I used the bag as a box with the speaker and port facing out of the bag and walled off the inside of the bag to get proper air space that is required. Was wondering if tuning it to a higher frequency would help or different type of enclosure (band pass/4th order)
Pics?
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
You're not really going to get performance with a 6.5" SW in an open air environment. In the most efficient well built enclosure it will be "meh" at best. Then fire up the engine on top of that, and you're not going to hear shit.
35 hz is pretty low for a 6.5" sub. So,yes raising it will make it louder. Honestly though ported isn't the way to go when they are facing an open environment. Probably sounds like a one note wonder huh? I would try sealed to spec and do not go any bigger ,make sure you are feeding good power. It will need it.
Sub / enclosure really needs to be mounted directly to the frame for best impact. And I would recommend sealed also.
Just saying ?
Maybe a sealed pair per side would get you something. But at speed, you're fighting an uphill battle. Good luck, I'd like to see pics.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
  • Who's Online   0 Members, 0 Anonymous, 486 Guests (See full list)
