Syphlyn Posted September 6, 2014 Report Posted September 6, 2014 Hey should I fuse between the alt and battery? mechman told me not to due to probable voltage drop across the fuse. All my wiring under the hood will have tech flex insultherm which is good up till 1200 degrees. The ring terminals will be soldered on and heat shrinked with those SHCA heat shrinks. It will be all away from moving parts/hot parts of the engine. What do you guys do and what should I do? Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
OrionStang Posted September 6, 2014 Report Posted September 6, 2014 I don't fuse mine, but many people do. If you took a true poll, Id bet it would be close to 50/50. SMD Super Seller My Feedback Thread
White Lightning Posted September 6, 2014 Report Posted September 6, 2014 I've never had a fuse between the alternator and battery. I'd follow Mechman's instructions ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
hdorre Posted September 6, 2014 Report Posted September 6, 2014 Just run the wire smartly On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
OrionStang Posted September 6, 2014 Report Posted September 6, 2014 Id also consider if your battery is under the hood, or in the back. Under the seat or in the trunk. If in the back, fuse it for sure. SMD Super Seller My Feedback Thread
Ritch40 Posted September 6, 2014 Report Posted September 6, 2014 i see no need for one between batts and alt. i do suggest you make sure there is one between the batt(s) and vehicle.
Syphlyn Posted September 6, 2014 Author Report Posted September 6, 2014 Id also consider if your battery is under the hood, or in the back. Under the seat or in the trunk. If in the back, fuse it for sure. i see no need for one between batts and alt. i do suggest you make sure there is one between the batt(s) and vehicle. Battery is under the hood probably a 24-30 inch run with wiring. BY battery to vehicle do you mean my main power run from the battery to the amp? If so, then yes of course. Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
DTS909 Posted September 6, 2014 Report Posted September 6, 2014 Just run the wire smartly x2 VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
deadbroke Posted September 9, 2014 Report Posted September 9, 2014 I wired directly to my battery not wasting money for those fuses but I did install a fuse between everything else on my battery positive
kylet1644 Posted September 10, 2014 Report Posted September 10, 2014 I personally would not as long as you have one on every battery.
