Fusing between alternator and battery?
Hey should I fuse between the alt and battery? mechman told me not to due to probable voltage drop across the fuse.
All my wiring under the hood will have tech flex insultherm which is good up till 1200 degrees. The ring terminals will be soldered on and heat shrinked with those SHCA heat shrinks. It will be all away from moving parts/hot parts of the engine.
What do you guys do and what should I do?
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
I've never had a fuse between the alternator and battery. I'd follow Mechman's instructions ...
:shrug: Just run the wire smartly
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Id also consider if your battery is under the hood, or in the back. Under the seat or in the trunk. If in the back, fuse it for sure.
i see no need for one between batts and alt.
i do suggest you make sure there is one between the batt(s) and vehicle.
Battery is under the hood probably a 24-30 inch run with wiring.
BY battery to vehicle do you mean my main power run from the battery to the amp? If so, then yes of course.
Sub: Sundown Zv4 12
x2
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
  • Who's Online   1 Member, 1 Anonymous, 1395 Guests (See full list)
