Hotdog Posted September 10, 2014 Report Posted September 10, 2014 I did some searching but could not find anything so I am going to ask a couple questions. 1. I was wanting to keep my back seats in my truck but I had a thought why not make a fiberglass mold of the back seat then make the whole back seat the enclosure. What would the process be on molding a big area or how would you tackle it. 2. This may be a stupid question but I will ask anyway because I do not know has anyone ever tried to use fiberglass resin over plastidip? (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
SIDE SHOW Posted September 10, 2014 Report Posted September 10, 2014 decent idea, fiberglassing big areas is hard to get right....
islandpride684 Posted September 10, 2014 Report Posted September 10, 2014 Wrong section bro, should have posted in here http://www.stevemeadedesigns.com/board/forum/15-fabrication-fiberglass-etc/ Why not build it using mdf and use upholstery foam for the top part where the seats would go.... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Berto Posted September 10, 2014 Report Posted September 10, 2014 Lots and lots and lots and lots of tape then fiberglass over? TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Katt Posted September 10, 2014 Report Posted September 10, 2014 Lots of blue painters tape, cover areas with plastic bags so it doesnt get all over, lay down yer mat, ( I find its easy to spray adhesive areas that the mat will fall down so it stays on sides and tops ) lay down yer fiberglass, repeat few times for strength, peel off, trim, and add your rings for your subs, then fleece over and fiberglass er and trim it all nice, bondo the shit outta it, sand smooth, vinyl or paint...I believe that is how she is done in simple explanation. I wanted to do it to mine, so i read a bit. And from what i gathered, thats how you do it. *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch*
