Sax 125.2 running hot?
Skax
Yeah that's weird, they are both off the same distro block then right? Maybe try retuning it?
didnt use a dblock just running them from battery and i bought it used
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
So how are they wired up then? Battery pos and neg going to the back connects to what, and from there then what.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
front batt to back batt with skyhigh 1/0 ofc from back batt 4ga ground and power to sax 125.4
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
if its not thermalling its fine.
as in going into thermal protection right?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
The average full range amplifier runs considerably hot compared to a mono block sub amplifier. It pushes out more frequencies than a mono block meaning it works ALOT harder. As long as it doesn't go into thermal protect ... You should be good.
BIG time if its a class A/B. Its kinda the norm. If its not shutting down, let it eat. :shrug:
Put it where it can dissapate the heat, maybe add some fans, but, ill bet its fine.........
  • Who's Online   0 Members, 0 Anonymous, 692 Guests (See full list)
