greg4510 Posted September 14, 2014 Report Posted September 14, 2014 hey guys im putting a little a bass in my nephews car a 1994 camry. he has already ordered 2 soundqubed hds212 subs. I have dims of 14high x 40 wide x 16 to 22 deep im looking to tune them about 36hz and plan on powering them with a kicker zx1500.1. any help would be appreciated
Joe X Posted September 14, 2014 Report Posted September 14, 2014 So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. How to do 45s if you decided to build them:
bcbrassard Posted September 14, 2014 Report Posted September 14, 2014 Nice design. If Joe X gives you a design on a enclosure I would build it. He helps tons of people on here and his designs are top notch. He designed a enclosure for my 2 HDS310s on 2K and it sounds great.
dharris2488 Posted September 14, 2014 Report Posted September 14, 2014 Joe X sent me a design for my HDS312's and it came out great... It'll sound good as long as you build it to spec. All on you Good luck! 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
greg4510 Posted September 14, 2014 Author Report Posted September 14, 2014 Doesn't 75 square inches seem a bit much at the power 1500 rms?
