Neo magnet > door flex
So I was brainstorming thinking how to rid or limit door flex, and I was thinking weight. But then I remembered the neo magnets meade used in applications. So I google searched it.
I'm thinking a few (3-5 per) in my rear doors will help stop the flex. If I use 2500 lb epoxy to secure them on to a part of my door that will contact or be in close contact with each other then would these work?
Now that I think about it I think I need two magnets one on the body one on the door for it to work. So I might have to go with thinner neo magnets. But what are your thoughts?
http://www.kjmagnetics.com/proddetail.asp?prod=DFH2
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Bolting it would be putting me out of stock class and into super mod really quick. 148db vs 164db. Sounds fair.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I really don't think they would help much with your doors flexing. I think that for it to work for that... You'd have to have enough of them shoved in there that you'd really be having a hard time even getting the door open when you actually want to open it.
I could be wrong though, but the kind of pressure that those doors have against them when they're really flexing seems like more than what magnets could really combat, and still be able to get the door to open.
I'm seriously considering it. It wouldn't be to make my rear doors unmovable. It would simply be to put 30-50 lbs of extra force on my rear doors since they are my most dominate flex issue ATM, but I'm sure once I fix that my attention will re focus on another one.
This one I'm thinking 2 or 3 sets of neo magnets per door. Each set would give about 16 to 18 lbs of force... So 3 sets would be 50 to 60 lbs of extra force. Will my rear doors suck to open? Sure. But It will only suck for the random friends who try to open them lol. I also think placement of these magnets is key rather then just grouping them all together.
I'm thinking bottom top and middle all on the outer most points on the latch side of my door.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Your the second person to say this. My friend David said that I'd need a crap ton of deadener in the doors, and maybe the magnets combined with the deadener would give me slightly better results.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
you ever planning on opening your doors? if the answer is no try it and see. you probably wont get them back open if you are using the high power nwo
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you think so? I was trying to gauge how much I could put on my door and still consider it openable. Not easy opening like a normal door. But....
The passenger side has some flex, not horrible. The driver has horrible flex, due to my b pillar and driver side doors being from a different accord and her having some shitty cheap body work. So I was kinda trying to combat that a little.
I was even considering maybe like 3 sets on the driver side and 1 set on the passenger side with bunches of deadener in each door. But then my OCD kinda kicked in.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
those magnets are stronger than you realize. I have some at home and they are pretty tough to pull a part jf you dont have a way to wedge something between them
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 4898 Guests (See full list)
