where are all of the diesel guys
Or a smaller turbo to spool the larger one.
More fuel than air, just unburnt fuel. most daily drivers only have this problem due to dirty tunes, or for the old school guys have pumps turned up and stock turbos. Naturally the more horsepower the more fuel that is needed and more turbo so it gets to a point where its unavoidable power will make smoke. I dont blow black unless im boost launching or an asshole tailgates me or acts foolish in their honda next to me.
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
Here's my dads ride. 06 F250 with 8" lift on 38x15.50 Toyo M/T's. pumps around 525-550 HP. 9i5rnd.jpg2gw8fet.png2pq00lw.png
Currently whipping a O4' GMC Sierra 2500
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
Flowmaster Super 10's
Magnaflow High Flow Cats
G2 4:88 running gears
New cooling system
Superchips Flashpaq programmer
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
8 Gauge Memphis Power wire
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
38x13.5 Toyo Open Country M/T's
18x10 Fuel Mavericks (-44 offset)
Diamond plate bed gaurds
Diamond plate tool box
Recon Xenon Bulbs in Highs,Lows,& Fogs
Recon LED Tail lights
AMP Research Automated steps
Not hating on any of you guys cuz non look that bad but why do you do a lower profile tire on a big lifted Truck? Why not stick with lower 20s and a bigger meet tire? Fill the wheel wells. Sorry just a pet peeve of mine to see people riding with a nice truck and lift and have stock sized or slightly bigger than tires but a big rim on it. Ig I'm a fan of meety massive tires. Once again none of you guys are to that point that Pisses me off. I just want an answer.
Most of us run the largest tire we can on our lift. I run a 4.5 in lift and 22x12's with 35's and still rub occasionally on a steep transition at full lock.
9AAA4552-F056-4BEB-A3F0-941A85C6852A_zps
A full wheel well to me on a lifted truck looks goofy because you have to run stock size width wheels to do so. I like a balanced look of lift, wheel width and tire. The dodge pictured with 14in wide wheels and 35's looks like its also running spacers to get them out even further. I dont care much for that particular look but on 37's his truck looks great.
Another reason I prefer a smaller profile tire is that its much more stable pulling my heavy trailer. I large sidewall has more roll and if your trucks puts in alot of actual work like mine does than you dont want 37's on a 18in tire. Atleast I dont.
I would like 37's also but I would have to atleast step up to a 6in lift to do so. But again since mine is a daily work truck I want it somewhat easy to get into.
2012 F250 Lariat 6.7, lifted on 22's and 35's
4 DSS Ethos 18's walled tuned low
2 Ampere Audio 7500.1's, Ampere 125.4
Rockford Pro Audio front stage
9 batteries, Mechman Elite 370 alt
Team DSS, Team Ampere Audio
2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals
32d73d87-e373-4a49-8914-d25decfa6dcc_zps
can u throw up some pics of ur system or a link to ur build log
Build Log
1996 chevy suburban
2 zv4 15
kenwood excelon mids and tweeters
kenwood excelon deck
mevhman 370
3 batts all different
mechman avmb II
2 inch squat
33 inch muds
straight pipes
kixker zx series 4ch
sundown amps
memphis 0 gauge
soon to be fu audio c pillar wall
1301EA76-62C2-4A0B-AC09-86536CE80D19_zps
16920167-506A-4E8D-8158-B65D7383DDFC_zps
Doors hold one 10in Punch Pro, and a Punch Pro Tweeter.
4E43D49D-32E7-4A0C-BB34-44F8F706A7F0_zps
AD84AE08-2A17-4023-9476-425635C0289E_zps
B523D932-AE59-4695-B571-58BB7FC93486_zps
13DC8962-0F6C-46CA-BC0B-986008361F18_zps
SWIFT..... that's a nice furkin powerstroke man!!
Thanks alot man, I'm proud of it. I've dumped probably 12k into it as soon as I bought it and havent even touched the motor or trans at all.
I will say I will never run another Rough Country lift. I have had nothing but issues with alignment up front. Seems like when I added the 2000lbs of stereo equipment in it it has gotten worse. I need to have it re aligned again and next time I will bite the (very expensive) bullet and go with a Icon lift.
OK that makes sense to me. To me that 6 inch lift would look bad to me if those tires were left on there. I was thinking more the guys that run like 26 inch+ rims and a 35 in tire or something like that. That low pro of a tire has no room in lifted trucks to me. But to each there own.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Yup, my 14 wides make bigger tires impossible. No swift no spacers here at all just -76 offset sets out that far. I can scrub 37s with my 10" lift if i hit a bump while turning at a quick speed. I had the 35x14.50r22 super swampers but they road soooo horrible that i went with toyos and i didn't want to stretch a 35x12.50r22 on 14 wides so i went with the 37s. Your superdirty is right on time to swift
